12-15-2005, 09:09 AM
Originally Posted by Pat2000 Cbass , thanks I would have to study those Augers to understand the mechanism better, I'd prefer to make my own pump cos of cost.
the Idea I've been toying with is along the lines of what they call 'window clings' thats using window paint see piccys below, the out line (which will perhaps be all i want is made from a black line usually.
the Glue they use seems to be based on PVA type of wood glue (the white stuff!!) when it is semi-dry 1-2 hrs, the coloured infilling is added , thats of a runnier viscosity, flexable and semi translucent - its all done on a plastic backing and the 'cling' (rather like a sticker) is peeled off the backing and will self-stick on glass.
It is still All plans on the 'back burner' as they say.
chances are that I will use my cnc router for all kinds of other purposes lol!!
i'm pretty keen also to make a tangential knife
It would probably be OTT for me to use a stepper driven auger partly cos of running out of controlable axis, I'm using two steppers on my x axis so thats 4 axis spoken for - a rotary exta axis would almost certainly be one of my future projects.
so anyhow if say a small stepper - printer type can be fairly easily driven by a simplish electronic drive all I'd hopefully have to do would be turn it on & off? driving it at a pre-set speed? ...
whey-hey boss mans says I can go in to work tomorrow and m/c parts for my router (on a days holiday) so I'm gonna fly me mill and rip-into a few parts!!
piccys from http://www.windowbutterflies.citymak...lyGallery.html
(site nothing to do with me!) |
Pat,
As is often the case, economics determine the type of solution we end up with. The auger type pumps are not cheap. I'm almost positive of this. I just brought them up because I thought they are simple in principle. You may be able to find one from some other application that will work for you. Heck, you might even be able to build one. Its not unlike a meat grinder in design, but you already know that.
Originally Posted by Pat2000 I'd imagined that the auger was also or mainly used to mix 2-part Epoxy glues as they are 'extruded' is that right? |
I don't think they are used for mixing, at least not the one I illustrated. If it was, it would be much longer and would require knife blades in-line with the auger to ensure mixing. I think they rely on a seperate mixng machine before it is fed to the auger...
Originally Posted by Pat2000 just found this on auger pumps - all a bit OTT (over the top) for my application but interesting for those following this - they reverse the auger slightly to stop/relieve pressure at the nozzle!! |
Thats whats so cool about this design. It has very precise control as rotary motion is translated into linear motion. A lot of similarities to why ball/lead screws are so great.
Carlo |
