Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 03-10-2011, 01:48 PM
bullseye is on a distinguished road
can someone make a dxf for me
I want to engrave this design for a Project and tried CamBam but having trouble figuring it out, can someone convert this for me 6 inchs long x .5 wide DXF
thanks in advance
Old 03-10-2011, 03:57 PM
mcphill is on a distinguished road
That picture is too pixelated to get good edge contrast from it. Do you have a much higher quality image?
Old 03-10-2011, 04:57 PM
Senna's Avatar
Senna is on a distinguished road
bullseye...
I drew it up in Freehand as the original was of poor quality... I've attached the DXF and a PDF just in case...
Happy cutting...!
BOOMER52
aka BOOMER52 >>> http://www.rcgroups.com/forums/member.php?u=159693
Old 03-10-2011, 05:56 PM
Originally Posted by Senna View Post
bullseye...
Happy cutting...!
BOOMER52
That looks awesome...thanks so much, can you thin it down to 1/2 inch and still keep it 6 inches long..even 5 would be ok
great job...I need to learn more how to draw this stuff up
Old 03-10-2011, 08:08 PM
Senna's Avatar
Easy enough... but what you are asking is a bit unclear. It seems the .5" H is your main dimension requirement... so making this image .5" H results in a width of 3.405" while maintaining the image ratio. Not certain that's what you are asking for so I also included one .5" H X 5.0" W. This required image stretching... it's the ONLY way to give you a .5" H by the requested 5.0" width...
B
Old 03-10-2011, 09:54 PM
B
Thanks...exactly what I want, I tried scaling it but like you said came out 3.405....Thanks a ton
What do you make or plan to make with your cnc router? piratecnc DIY-CNC Router Table Machines 27 11-14-2010 01:46 AM
Need Help!- How To Make Changes SPEEDRE Autodesk Software (Autocad, Inventor etc) 3 02-24-2008 03:26 PM
How do I make this cut? juliancrouch General Metalwork Discussion 12 02-13-2008 12:11 AM
Best Way To Make This? DroopyPawn General Metalwork Discussion 8 12-15-2007 11:34 PM
How would you make this? Art Ransom Wood Lathes / Mills 5 01-09-2007 06:03 AM
