Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 10-30-2010, 11:43 AM
citrusguy is on a distinguished road
Question Engraving PVC Pipe
I have built a cnc "lathe" to engrave cylinders, and I am seeking advice on the type of bits to use to engrave lithophanes on PVC pipe. I have tried 30° V bits, but results are dismal due to the PVC melting. I am presently using a Dremel, but will install a trim router (Bosch or Ridgid) soon.
I use my own gcode conversion program and usually engrave with a step over of 0.005 to 0.010 inches.
Thanks for any advice.
John
Old 10-30-2010, 12:05 PM
ger21's Avatar
If it's melting, slow down the rpm.
You might want to try small ballnose cutters.
I know member Greolt has done the same thing, you might want to ask him.
Old 10-31-2010, 07:54 AM
Thanks Gerry.
I am not sure melting is the cause, but my present bit is leaving lots of "fuzzies" on the final image that degrade the work. Perhaps the bit is not cutting properly. I am running the Dremel at it slowest speed. I will see if I can find a way to slow it down even more, or go ahead and change to a trim router with an external speed controller.
Regards,
John Champlain
Old 10-31-2010, 04:55 PM
gmfoster is on a distinguished road
If it is melting try a stream of air to cool it.
Old 11-14-2010, 11:14 AM
JD_Mortal's Avatar
JD_Mortal is on a distinguished road
Warning, PVC releases highly cancerous and toxic fumes when heated and melted. Poly Vinyl Chloride is dangerous to melt or mill. Plumbers only make small single cuts along a length, a few thousand in a lifetime will not add-up to the carving gasses you will be releasing in one multi-layered milling of a 2' section of tube.
Just make sure you use adequate ventilation, if you MUST use PVC. Also be sure to coat the finished product with some PVC safe clear-coat or paint. The pipes are coated with a anti-seepage layer, approved for use with water. The heat releases the chloride when milling.
I suggest that you use ABS plastic or acrylic tube, if possible. Even HDPE or PE tubes.
Old 11-15-2010, 01:26 PM
beone is on a distinguished road
try a lube-- dish detergent watered down 50-50 works well for plexiglass
In the words of the Toolman--If you didn't make it yourself, it's not really yours!
Remember- done beats perfect every time!!
Old 11-16-2010, 09:15 PM
mactec54 is on a distinguished road
JD_Mortal
I'm always amazed at what people can come up with about PVC
citrusguy you can machine this material all day every day of your life & it will not hurt your health in anyway
The only time it can cause you a breathing & health problem, is if you burn it, like on fire, it then will give off Hydrogen Chloride gas & Dioxn
Most of the other plastics that JD_Mortal has listed can be just as Toxic as the PVC if Burnt by fire as well, it just depends, on what additives, fire retardents are used in there formulation
The formulation of PVC is CH2=CHCL= is a double bond thermoplastic material
You don't have to coat it with anything after it is machined as well
There was a guy in Australia, that was doing the same as what you are, & got the fuzzy stuff as well, he just brushed it with a stiff brush to take the fuzzy bits off
But I'm sure if you cut it at the right spindle speed & cutter it will cut clean, without the fuzz
Mactec54
Old 11-27-2010, 10:56 AM
Thank you all,
I appreciate your input. For now, I have set aside rotary work in order to have time to make Christmas gifts for family and friends. As I work on this project later, I will post my findings.
Happy Holidays to All,
John Champlain
Old 12-15-2010, 11:30 AM
dxhale is on a distinguished road
I have also been trying to find the perfect combination ( step over, feed, tool) to make a good litho out of pvc pipe. I first used a 30deg bit and ran into the fuzzy problem, so bad that even taking a brush to it was not practical for me. My last attempt was using a 3/64 3flut ball EM with .005 stepover. The result was not fuzzies but a lower quality image.
gas pipe or hot/cold water pipe? jaymed2000 JGRO Router Table Design 2 03-15-2008 09:01 PM
Instead of Gas Pipe Bartsimsonii JGRO Router Table Design 3 11-19-2007 08:39 AM
pipe tap toolendmill BobCad-Cam 3 06-26-2007 12:52 PM
emt conduit, galvanized pipe or black pipe? JohnG DIY-CNC Router Table Machines 5 05-21-2006 08:24 PM
Using Pipe Nightz DIY-CNC Router Table Machines 2 10-16-2005 06:07 PM
