Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 09-26-2010, 07:02 PM
mayhugh1 is on a distinguished road
Kinetic Yard Art Project
I'm getting ready to get back into my shop to continue work on my V4 engine project since the Texas heat here is finally starting to die down some. I usually work on larger outdoor projects during the summer, but this past summer I designed and built a piece of kinetic art in a rear corner of our yard that you might find interesting. A Youtube video that I made of it running (during a rainstorm, in fact) is located here:
YouTube - Kinetic yard art.MP4
The two spinners are 54" in diameter and the whole piece of art is fabricated from 303 stainless bar and .030" copper sheet that I have had laying around for some 20 years. Each spinner rotates on a pair of sealed ball bearings and the whole assembly rotates on a pair of radial/thrust ball bearings. I was able to achieve a balance such that 5 grams of weight on any arm will cause either spinner to rotate a quarter revolution to a stable position at the bottom of its rotation.
The interesting part from a machining perspective, though, might be the way I formed the compound copper cups at the ends of the arms. I used SolidWorks to design the positive half of the mold and then mirrored it with a .060" offset to create the negative half. Sprutcam created the toolpaths. The mold halves were machined from glued up blocks of red oak that I had laying around. Total machining time was about 1 hour per side as I was able to feed close to the limits of the machine. I had plastic garbage bags taped around the workpiece to keep the wood shavings from making a mess in the chip tray. And the cutter inadvertently caught one of these and made things exciting for a while. After annealing the copper blanks with an acetylene torch I used my homemade 20 ton press to press out the 16 cups. The cups are about 17" long by 6" wide by 1.5" deep. The mold was also used as a drilling jig for the fasteners that secure the cups to the SS arms. - Terry
Name:	Machining pos side of mold_.JPG‎
ID:	115571   Click image for larger version
Name:	Machining neg side of mold_.JPG‎
ID:	115572   Click image for larger version
Name:	Completed Oak Molds_.JPG‎
ID:	115573   Click image for larger version
Name:	Pressing copper blanks_.JPG‎
Old 09-26-2010, 07:18 PM
chuck_hobby is on a distinguished road
Thumbs up
Great work! Looks like an inspired project.
Old 12-21-2010, 10:50 AM
Horsedorf is on a distinguished road
Oh nice!!
THAT is nice. Very well done, there!
Old 04-10-2011, 11:22 AM
twoartistic is on a distinguished road
Great project. I couldn't tell from the video, does the drag on the cups keep them aligned with the wind?
I used the same design intent to make pressure molds for a longboard company. I then machined the mold halves out of oak blocks I had glued up. The molds where 4ft long x 1ft wide x 7 inches total thickness of the two halves. They use a 500 ton press I designed for them, to press between 3 to 8 longboard blanks at a time. Or used to anyway, I heard they fell victim to the economy.
Machine scrap yard in Seattle area? Darren_T DIY-CNC Router Table Machines 9 05-14-2011 04:16 PM
scrap yard or junk yard in Toronto area Talex Benchtop Machines 16 01-25-2011 09:05 AM
Build Thread- Kinetic art laser "gun" with stepper motors BioMicro Hobby Discussion 5 01-07-2011 08:21 AM
free stepper and controller card in your junk yard??? patriciooholegu Stepper Motors and Drives 3 12-05-2007 10:39 AM
What is a fair price for scrap yard aluminium ? vroemm CNCzone Club House 15 08-13-2007 02:35 AM
