Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Machine Created Art
Machine Created Art Discuss art created by machines here.
Old 04-24-2010, 07:38 PM
gda gda is offline
gda is on a distinguished road
Need help choosing software
I have access to Mach3,Rhino, Visualcam, and I have a demo for BobCad. I need to be informed on a user friendly Art software, or CAD program to go with either one of these. I am slightly familiar with Rhino which I suppose could be used for the CAD or the art end of it all, along with RhinoCam. I don't know if it comes equipped with features for placing text on an arc or in a circle, or If I am better off purchasing an Art program for the art end of one of the others that I have. I also have Casmate, which is a real good program for making signs and plaques, etc, which is what I want to get my feet wet with. I am assuming that what I have will turn my artwork into G-Code and run the machine on the correct tool path . I realize that I have very little knowledge in this area so please give an admitted newbie whatever assistance and advice that you can. My intentions are to use this software that I end up with on a benchtop mill, that I will use for engraving plastic plaques and such, and when I want to do anything 3-d, I will use a stl file that will be provided to me by a friend that has a scanner.
Thank you in advance,
gda
Old 04-24-2010, 09:25 PM
ger21's Avatar
Look at www.Vectric.com
V-Carve Pro is great for doing signs. For the .stl's, you'll need something like their Cut3D. Or www.meshcam.com
Newbie- Need help choosing lathe cad/cam software for Mach 3 aaronwelder Mach Lathe 4 04-13-2010 06:48 PM
Help choosing CAD/CAM software that simulates gears and springs en20r954 General CAM Discussion 0 12-12-2009 07:56 PM
Newbie- Help choosing the right software, raised lettering signs. Dazza General CAM Discussion 1 07-08-2008 05:57 PM
Choosing a spindle egberttheone Open Source CNC Machine Designs 0 02-21-2007 12:38 PM
Need help choosing lmartin1001 Benchtop Machines 2 10-13-2006 01:24 AM
