HU. I suspect it might not be airborne but either something has changed regarding grounding or there is alot of noise going back into the line from the plasma, if you use the plasma on a fixed table, make sure it is well grounded and you could also sink a ground rod next to the table. An inline choke on the plasma ac supply could be an option also.
Usually, air borne interference does not blow fuses in adjacent equipment.
Al
