- Need Help!- Loses program MX-1 on shutdown
Why does my MX-1 dump the program in memory when I shut down controller?
If I purge the controller so no programs are in and load a program using cadem, I can run it but when I shutdown controller the program is gone...
Is anyone still using these things or am I killing myself...? Control doesn't lose offsets.
%O1234
N1 G40 G49 G80 G00
N2 G91 G28 X0 Y0 Z0
N3 G45 X0 D98
N4 G45 Y0 D99
N5 G92 X0 Y0 Z0
N6 G20 G90
N7 (Setup 1)
N8 (Work Zero)
N9 (Face Top)
N10 T03 M06
N11 S3500 M03
N12 G00 X-7.6259 Y-7.64 T1
N13 G43 Z0.25 H03
N14 M08
N15 G01 Z-0.03 F27.
N16 X0.1259 F54.
N17 Y-7.265
N18 X-7.6259
N19 Y-6.89
N20 X0.1259
N21 Y-6.515
634 M06
N635 S1500 M03
N636 G43 Z0.25 H05 T3
N637 M08
N638 G00
N639 X-5.6062 Y-1.8939
N640 G81 X-5.6062 Y-1.8939 Z-1.17 R0.22 F10.
N641 G80
N642 G00 Z0.25
N643 X-1.8938 Y-5.6062
N644 G81 X-1.8938 Y-5.6062 Z-1.17 R0.22 F10.
N645 G80
N646 G91 G28 X0 Y0 Z0
N647 M46
N648 M30
Re: Loses program MX-1 on shutdown
The reason is the battery is dead. why it remembers everything else is beyond me.
Your program number is on the same line as the %. I think you need an EOB after the program number.
- You may not post replies
- You may not edit your posts
Forum Rules
