Hi sorry if this is the wrong area please move if needed.
Have an amada Vipros 357 here 2 weeks ago fired it up ready to reference close the clamps and nothing happens the motor didn't kick in had the no 14 emergency reset/ alarm, left this for a day following day had no issues what so ever fired up and referenced to run no problems.
Today during running a job thats been running for the last 3 days half way through a sheet this error kicked in, can't clear it, turned the machine off for a couple of hours to try re-reference and nothing, Now the thing is if you leave clamps open and fire it up the motors kick in as soon as you shut the clamps it cuts out, any ideas guys would be appreciated.
hope you did not loose the NC & DGN parameters !
what are power conditions where the machine is installed...? sudden drops or power down in ' EDIT' sometimes looses the crucial parameters.
try restoring the parameters and you should be fine.
