Problem Need Help Programming Actions!
Results 1 to 2 of 2
Thread: Need Help Programming Actions!
    Jul 2014
    Default Need Help Programming Actions!
    I need to cut out about 300 Steel squares with a hole in the middle of each of them. The issue I'm facing is that the laser CNC wants to cut the squares out first and then route back to cut the holes. Well the problem is, the squares drop down into the coolant when the are cut so, the holes can't be cut after that. How do you program it to cut the holes first, then come back and cut out the squares?
    Community Moderator wendtmk's Avatar
    Dec 2005
    Default Re: Need Help Programming Actions!
    Sounds like a CAM programming issue?
    What CAM are you using?
