Vipros 358 penatration problem
Results 1 to 5 of 5
Thread: Vipros 358 penatration problem
    Feb 2013
    Default Vipros 358 penatration problem
    I have Vipros king 358 with 04 pc controler. One of my guys shut down amada in edit mode. We cleared and reinstalled 9201 to reset parameters. Now I have a penatration problem. Oil presurre light comes on after every hit. We are not low on oil. I got the 9201 straight from Amada. Before I pay an arm and a leg for a tech I thought I would throw it out there to see if anyone can help.
    Aug 2011
    Bogotá, Colombia
    Default Re: Vipros 358 penatration problem
    hello i like know is your problem and if you have the parameters of this machine becouse i need this paerameters thankeo
    Oct 2005
    INDIA
    Quote Originally Posted by hoffman102 View Post
    hi hoffman,
    can you please send me the 9201 Macro & the other param backup ,
    as i have lost my machine parameters and would like to try & edit your parameters on my machine to put it operation.
    please send at parag.pitre@gmail.com
    thanks,
    Oct 2005
    INDIA
    by the way you please check the Accumulator Gas pressure for the penetration problem you have. May be the pressure is less or the bladder is punctured.
    thanks.
    Oct 2005
    INDIA
    Dear Hoffman102,
    Is your problem resolved..?
    By the way ...do you have the electrical drawing of Vipros 358 ( 04PC ) machine.....if so could you please extend your help to send me the same..?
    thanks.
