3d puzzle dxf files - Page 2
Page 2 of 7 FirstFirst 12345 ... LastLast
Results 21 to 40 of 125
Thread: 3d puzzle dxf files
  1. #21
    Member Weldtutor's Avatar
    Oct 2005
    Arrow Re-sizing puzzle slot
    Quote Originally Posted by Jay C View Post
    can someone explain the easiest way of scaling just the slots?
    Check this LINK for a simple way to re-size puzzle slots for different material thicknesses.
    It shows a very easy method!
  2. #22
    Oct 2005
    Default Puzzle Slot Re-size
    The file in the above link has now been moved to an unknown location.
    To re-size a puzzle slot, in my progeCAD program, this is how I go about it.
    -choose MODIFY
    -highlight one side of the slot
    -click OFFSET
    -input the DISTANCE TO OFFSET example .125" (if original slot was .250")
    -click where you want SIDE TO OFFSET
    The above will give you a center line for the new slot.
    Then DRAW NEW SLOT around the center line, to desired size.
    Delete the old slot & the center line you drew, which leaves a new slot the size you drew.
    It is easy after you do it a few times.
  3. #23
    Feb 2009
    israel
    Stance for CD please
  4. #24
    Apr 2004
    canada ontario
    Smile
    Does anyone have a 3dm or stl of a horse, complete or even just the head. my mother in law wants me to do a 3d carving for her before she goes back home,thanks in advance i would appreciate it,cheers.
  5. #25
    Oct 2008
    NZ
    I made mine big...
  6. #26
    Jun 2007
    I made mine small.
    3d puzzle dxf files-assymbley-7-jpg
    3d puzzle dxf files-cutting-finished-2-jpg
    3d puzzle dxf files-pieces-cutter-2-jpg
  7. #27
    Nov 2005
    Default T-rex
    This t-rex is made of 1/2" Extira MDF, about 4ft high
    http://tienganh.net/ese/showthread.php?t=6143
  8. #28
    Jan 2010
    indonesia
    Great design i hope it can work on my sherlene cnc mill
  9. #29
    Feb 2007
    Default crocogator
    I am looking for a puzzle of a crocodile, or alligator.
  10. #30
    Feb 2010
    Italy
    Unhappy butterfly.dxf
    hellp , im looking for butterfly.dxf
  11. #31
    Member bigz1's Avatar
    Apr 2006
    NZ
    Quote Originally Posted by layertone View Post
    Great job.
    Would you mind sharing your file?
  12. #32
    Dec 2004
    Memphis, TN
    That one is part of the dinos font IIRC. You need me to post the font?
  13. #33
    Apr 2006
    NZ
    I have the font thanks Jay C.
    Unfortunately I have tried using the dinofonts before but they are a little too rough for my liking. Using the same cutter for the material thickness they still don't seem right. Really they need slots manually put in and the rough vectors cleaned. Layertone has taken 40 hours to clean up this one. I can appreciate the effort after 4 days of working on the ship set I still haven't got upto the sails!!!
    My 3 year old Paleontologist seams to think this is an Allosaurus and not a TRex.
  14. #34
    Dec 2004
    Memphis, TN
    Quote Originally Posted by arkadian86 View Post
    Look here
  15. #35
  16. #36
    Jul 2008
    us
    If you are looking for clean ready to cut dxfs, check out www.centracraft.com. Construct'ems cnc projects. Also include good assembly instructions so you can easily put it together when its done.
    T-rex, alligator, insects, ect....
  17. #37
    Oct 2008
    NZ
    haha yea assembly without instructions can take longer then the actual machining process!
    I know it did for the Eiffel Tower, as with my router it left wee radii in every corner which needed cleaning up manually
  18. #38
    Dec 2007
    Here is a video of sketchup model I built from one of the online dxf files.
    [nomedia="http://www.youtube.com/watch?v=lE2qDfqhog0"]YouTube- a03[/nomedia]
    Here are some pics of a velociraptor I did for my kids, they have loved it. I scaled it to use 1/2 inch material and to be full size. My daughter took it to school for "show and teach" and it was a huge hit.
  19. #39
    Jun 2010
    Brasil
    Boa noite!!!
    desculpa-me por posta,pois não sabia como posta,mas fico muito agradecido por me aceitarem na comunidade.
    Benigno
  20. #40
    Nov 2010
    Anyone have a dxf for a spider like a tarantula
3d puzzle dxf files
3d puzzle dxf files
