CNC egg shell carving - Page 4
Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 129
Thread: CNC egg shell carving
  1. #61
    Nov 2015
    Default Re: CNC egg shell carving
    bas-relief test of the new machine
    1mm relief depth.
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-img_5524-jpg   CNC egg shell carving-img_5524-jpg   CNC egg shell carving-img_5528-jpg
  2. #62
    Jun 2010
    A little gold trim and you could have Faberge eggs.
    Cheers
    Roger
  3. #63
    Jan 2014
    Wow... that's some pretty amazing stuff.
  4. #64
    Nov 2015
  5. #65
    Oct 2016
    United Kingdom
    What an amazing job!!
    Inviato dal mio SM-N9005 utilizzando Tapatalk
  6. #66
    Nov 2015
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-01-jpg
  7. #67
    May 2009
    I love it. What bit did you use for this last egg? How far apart is the spacing on the egg surface probing?
    Sent from my SM-N920V using Tapatalk
  8. #68
    Nov 2015
    Quote Originally Posted by newlife View Post
    Hi newlife,
    I used the diamond coated grinding bit.
    And the spacing is 2.5mm.
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-cccc-jpg
  9. #69
    May 2009
    Very nice detail work. How are you doing the back light? Led inside?
  10. #70
    Nov 2015
    Thx newlife.
    And yes, there is a LED inside.
    It is a 1W LED on a lamp socket.
    CNC egg shell carving-p61124-215219s-jpg
  11. #71
    Nov 2015
    Goose egg shell lithophane
    CNC egg shell carving-02-jpg
  12. #72
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Gilbert Az
    This is so neat, thanks for detailing this. Looking forward for more updates.
  13. #73
    Sep 2003
    Gilbert Az
    Quote Originally Posted by uvvvvw View Post
    Hi John,
    I mount the mechanical probe directly in the machine.
    And after the scanning, I replace the probe with the spindle.
    As the depth control is crucial, it is not OK to scan the egg profile in other machine.
    Regards
    You say you scan the surface of the egg, do you mean just one horizontal line scan, or do you do one horizontal scan then rotate X amount and make another horizontal scan so that you scan the countour of the entire area to be cut?
    I really appreciate your design and work, a true artist .
    Hager
  14. #74
    Sep 2006
    Wow, those are truly amazing. You say that it is just a hobby, but it appears that you have built quite a collection. Do you sell any of them?
  15. #75
    Nov 2015
    thx Hager.
    and yes, i scan the countour of the entire area to be cut.
  16. #76
    Nov 2015
    Quote Originally Posted by steve323 View Post
    thx Steve. i gave most of them to my friends
  17. #77
    Nov 2015
    Some more lithophanes
    CNC egg shell carving-img_5798-jpg
    CNC egg shell carving-img_5770-jpg
    CNC egg shell carving-img_5771-jpg
    CNC egg shell carving-img_5776-jpg
    CNC egg shell carving-img_5785-jpg
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-img_5797-jpg
  18. #78
    Nov 2015
    dog and cat
    CNC egg shell carving-img-20170117-wa0001-jpg
    CNC egg shell carving-img-20170115-wa0002-jpg
  19. #79
    Jun 2010
    You are getting very good at this!
    Cheers
    Roger
  20. #80
    Nov 2015
    thx Roger
