CNC egg shell carving - Page 2
Page 2 of 7 FirstFirst 12345 ... LastLast
Results 21 to 40 of 129
Thread: CNC egg shell carving
  1. #21
    Nov 2015
    Default Re: CNC egg shell carving
    [QUOTE=JohnReierson;1834592]
    Based on the picture the probe and spindle mount appear to be 3d printed?
    [It is nylon, turned by a lathe. Tried before 3D printing, but the concentricity is not good.]
    Is the rotational axis that drives the spindle driven by a worm gear?
    [Yes originally. But changed to other gear drive with less backlash.]
    What made you decide to build this machine?
    [Just for fun originally. Right now making a bigger one for Ostrich egg shell. Try to develop some business opportunity ]
    I only have experience running a simple lathe or mill cnc: Is it harder to program this machine due to the two rotational axes (specifically the one that moves the spindle)? Are you running Mach3? If so, was it hard to set up the rotational axis to work on a cartesian coordinate system?
    [I am using Mach2. I just cheat the system that I am working on 3 linear axis, that are X,Y and Z axis. Experience in CNC milling is more than sufficient]
    I was thinking of building a SCARA 3d printer, but I have no idea how I would program it to work.
    [Tons of learning materials in the net. Just spare some time for it will be OK ]
  2. #22
    Dec 2009
    Hi I am interested in what software you used to do the probing
    I just tested 4th axis probemaster in mach3
    and I am a little confused because the data created is in x,y,z which is fine, but there is rotational data
    so when I import the data into Mastercam it comes in with all lines in the same plane.
  3. #23
    Nov 2015
    Quote Originally Posted by squirrel_41 View Post
    Hi Squirrel,
    Got no idea on the Mach3 probemaster, as I am still using the old Mach2.
    And I wrote my own program to do the probing, used the old Visual Basic 6
  4. #24
    Dec 2009
    Okay I can do do the programing but I need to be pointed in the right direction
    the 4th axis probemaster returns all values for y as 0
    So for all intents this is the same as a "single line 2d surface probe" moving only in the x direction with a z height
    So if Y was converted to a value equal to the 4th axis rotation in a flat plane the data should represent a undulating 2d surface that I should be able to roll 360 Degrees.
    Or can I get a copy of your probe routine.
    Cheer's.
    Okay I think I have a simple fix I'll create a program to rotate all data at X degrees a round the rotary axis.
    Okay I built a macro in Mach3 that does all the conversion works real good.
  5. #25
    Feb 2016
    United Kingdom
    amazing
  6. #26
    Nov 2015
    Drilled 18.750 holes by 0.3mm dia PCB drill bit.
    Position accuracy deteriorated significantly after drilled by about 2000 holes.
    But luckily, no drill bit breakage after all holes have been drilled.
    Attached Thumbnails Attached Thumbnails CNC egg shell carving-1-jpg   CNC egg shell carving-2-jpg
  7. #27
    Member dharmic's Avatar
    May 2015
    Gosh.
    How long did THAT take?
  8. #28
    Nov 2015
    Quote Originally Posted by dharmic View Post
    Gosh.
    19 hours !
  9. #29
    Nov 2015
    Gosh.
    19 hours !
  10. #30
    Member SignTorch's Avatar
    Jan 2011
    golly - a chicken takes 26 hours to make an egg - amazing - the egg and the carving - I love seeing these - keep 'em coming....
    www.signtorch.com
  11. #31
    Nov 2015
    CNC egg shell carving-img_6775-jpg
    CNC egg shell carving-img_6774-jpg
  12. #32
    Nov 2015
    Some more
    CNC egg shell carving-img_7673-jpg
    CNC egg shell carving-img_7629-jpg
    CNC egg shell carving-img_7633-jpg
    CNC egg shell carving-img_7639-jpg
    CNC egg shell carving-img_7672-jpg
    CNC egg shell carving-img_8792-jpg
    CNC egg shell carving-img_8794-jpg
    CNC egg shell carving-img_8798-jpg
    CNC egg shell carving-img_8804-jpg
  13. #33
    Jun 2010
    Boggle!
    Amazing stuff.
    Cheers
    Roger
  14. #34
    PAPACAI's Avatar
    May 2016
    CHICLANA
    Bunos dias .
    busco planos para la construccion de una cnc pequeña para iniciarme en este tipo de trabajos
  15. #35
    Dec 2009
    Quote Originally Posted by uvvvvw View Post
    Hi Squirrel,
    What are these eggs from chicken, duck, emu
    thanks
  16. #36
    May 2015
    wow.
  17. #37
    Nov 2015
    thanks
    Goose mainly.
  18. #38
    Dec 2009
    Thanks for that I have tried standard egg shells but the shell always break
    they are really thin.
  19. #39
    Jun 2010
    Of course, if you used a very fine sand-blast jet, or a laser, you might manage those too?
    Cheers
  20. #40
    Nov 2015
    Rio 2016 Olympic Logo
    CNC egg shell carving-egg-jpg
