Yes,but the resolution of this jpeg is too low. You would need to purchase the rights for this image and then it could be easily transformed.
Hallo
can some1 make a dxf from this file? ive found a similar "calender" in a other post but if it is not too much work would be nice to get exactly this one.
nice greetings
dave
Try this tread
http://www.cnczone.com/forums/bobcad...mayan+calendar
oups did not notice it was not the same ... sorry
Same here, I could help you, but I need a higher res image. Sorry...
WIN Topo standard (FREE!!!) works very well on this image even though its low res.
SoftSoft.net : WinTopo Raster to Vector Converter
the file is here
Vector Image Files
for CNC woodcarving - 3d puzzle - furnitures
http://pagesperso-orange.fr/fabrun/
my attempt for making a dxf
(could be better with higher resolution picture)
https://rapidshare.com/files/2912592788/mandala.zip
you can always pass it thru inkscape to clean it up- and out put it to whatever you need from stl, to dxf, or even bmp.
