Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 01-18-2010, 12:57 AM
Bob La Londe is on a distinguished road
Shapes 2d V2
Shapes 2d V2
I have been playing with and taking advantage of some of the wizards lately, and this one looks like it would work right into one mold making project I am working on, but I can't figure out how to save or retireve the g-code or if it is even generating it.
Is there a place to discuss or ask questions about Shapes 2d V2 by German Bravo?
Bob La Londe ~ Owner of two and a quarter G540s.
www.YumaBassMan.com
Old 01-18-2010, 01:56 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Bob,
This may help.
http://www.newfangledsolutions.com/d...nual_v2_75.pdf
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 01-18-2010, 02:08 AM
Originally Posted by jalessi View Post
Bob,
This may help.
Jeff...
Thanks, thats a great manual, but its not the one I am looking for. Shapes 2d is a different wizard.
www.YumaBassMan.com
Old 01-18-2010, 08:47 AM
ger21's Avatar
You can ask right here.
Click the "gcode" button, and you'll see the toolpaths appear. Then "Return to mach3", and you'll be ready to run.
Be sure to hit "enter" after entering any numbers, or they won't be accepted.
Old 01-18-2010, 10:38 AM
Ok, I must be missing something then. That's what I am doing and its not happening.
www.YumaBassMan.com
Old 01-18-2010, 11:09 AM
ger21's Avatar
You probably are not entering info in a required DRO. Can you post a screen capture when it won't give you the code?
Old 01-18-2010, 12:44 PM
I will see if I I can setup screen capture on my controller computer. I'm not getting any of the scrolling error codes. I keep it stripped down and not on the network.
I experimented some on this computer (but this one is full of crap and slow) and when I do get codes they are just G & M codes. No spindle X,Y,Z moves.
www.YumaBassMan.com
Old 01-19-2010, 07:05 PM
One of the guys on the Artsoft Mach Support Forum Gave Me the Answer
One of the guys on the Artsoft Mach Support Forum gave me the answer.
A lot of the Wizards do not like defaults. With most of them you are setting every variable, but the Shapes Wizard is so flexible, that many items you leave at the zero default. It doesn't like it. Even if leaving an item at zero, open the field enter zero, and then press enter to save it.
When I did that using all the same data it work the first try. I am cutting a test piece now.
www.YumaBassMan.com
Old 01-19-2010, 09:42 PM
ger21's Avatar
I think you missed a critical DRO, like the radius (it's called something else). When I did the test, I left about half of them at their defaults (some were zero), and it worked fine.
From my experience, if a wizards not working, you're leaving out critical info needed by the wizards.
But anything's possible, I guess.
Old 01-19-2010, 11:59 PM
I suppose but all I did was click on each data entry and then hit enter from my previous saved values and zeros. Then it worked. I think I found another bug in this particular wizard so there may be more than one thing going on. A test run on his "Circle" cut came out lemon shaped.
www.YumaBassMan.com
  #11   Ban this user!
Old 01-20-2010, 02:46 PM
Playing with some of the other shapes in this wizard to see what else I could find I had an artifact destroy a another test piece. In the rectangle tool of all things. Just for fun I decided to try and use the rectangle tool to make a two piece box that fits together tightly. I cut a pocket in one piece and a relief on the next, and fitted them together. Then with the two pieces fitted I decide to cut them both around the outside (relief) to match smoothly ont he outside. For no apparent reason there was an artifact or bad cut that went right onto the material that was supposed to be left behind.
I do not think I'll be using this wizard much at all.
I'm sure glad I tested it on some scrap MDF before trying to make something with it.
www.YumaBassMan.com
Looking for more into on tooling/mold for EPS shapes SteveC68 Moldmaking 4 11-28-2008 09:35 AM
Farm animal shapes PlasmaGuy CNC Plasma and Waterjet Machines 2 03-21-2008 01:47 PM
Scan-Import Shapes edwardpic CNC Plasma and Waterjet Machines 2 10-04-2006 11:41 AM
Shapes Wizard rweatherly Mach Wizards, Macros, & Addons 0 05-23-2006 08:24 AM
Surfaces with Human Shapes CAMFUN General CAM Discussion 15 06-22-2005 08:18 AM
