Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 12-27-2009, 11:01 PM
justCNCit is on a distinguished road
second parallel port address
not sure if this is the right topic, however, I have installed a second parallel port into the computer. the drivers seem to have installed fine.
Its a rogers encoder interface. I double checked pinouts and ports & plugged it into the first parallel port, and got feedback and it worked fine.
however, it seems that no matter which address I use for the second parallel port in Mach, there is no feedback or contact with the board. I was able to tell originally that the settings were correct when the parallel port lights on the diagnostic screen lit up. but that only appears to work for the first parallel port. so has anyone else had this difficulty ? thanks.
C++, Win XP, Parallel Port Zumba Coding 7 03-29-2012 01:12 PM
USB to Parallel port?? willio Shopmaster/Shoptask 25 11-12-2009 02:42 PM
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
Where's the parallel port? cdlenterprises Mastercam 23 01-20-2007 05:23 PM
Second parallel port? essa LinuxCNC (formerly EMC2) 11 04-12-2006 02:18 AM
