Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 12-16-2009, 11:17 PM
glengeniii is on a distinguished road
Need to asign a M number to this auto tool zero macro.
How can I assign a M number to this macro I found that is for the auto tool zero button. I would like to be able to use the button to zero the tool, and I would also like to assign a M-number so that immediately after a tool change, the the macro will be ran, the tool will be zeroed and the program then continue.
Example :
M28
T3 M06 G43 H3
M99991 (Auto zero's tool)
M1 (press cycle start to continue)
G0 z.375
Also, I would like to know if after the probe is triggered, does the z axis de-accelerate normally, or does it come to an abrupt stop (like when an e-stop is triggered). I'm afraid the I'll lose steps in absolute coordinates on the z axis with my stepper system.
Here is the macro I found:
Put a user DRO on the screen using Mach's screen utility, Screen4. Assigned it OEM code 1151
Also put a LED for Probe and one for Pause or Dwell. These I will explain later. See the screen grab below as pic.
Assigned the following macro to the "Auto Tool Zero" button.
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P5" ' this delay gives me time to get from computer to hold probe in place
Code "G31Z-40 F500" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
Code "G0 Z25.4" 'put the Z retract height you want here
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Else
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
Exit Sub
End If
Old 12-16-2009, 11:28 PM
ger21's Avatar
Save the macro as Mxxx.m1s and pu it in Mach3\macros\yourprofile\
Not sure about the 2nd part, but you can set the feedrate low, so you shouldn't have a problem.
Old 12-31-2011, 02:33 PM
carbideuk is on a distinguished road
assign macro
hi that seems so simple but it does nothing in my screenset I get not yet implemented message in my ststus bar. am I missing something?
Old 12-31-2011, 03:10 PM
ger21's Avatar
If you created an M Code, you need to edit the screen in a screen designer so the button calls that M-Code.
Or, you use Operator > Edit Button Script, then click on the button, and add the code right to the button.
Old 12-31-2011, 04:26 PM
m code
many thanks i have created the m code ok and it works fine I am still not sure how to apply it to a button in the screen set i was using the blue screen but the auto tool zero button seemed to be locked it was not available from operator/edit button/script. however i have gone back to my initial 1024 screen and now i was able to apply the script to the auto tool zero button.
Hurray!! many many thanks
Tags
macro mach3 tool zero
number engraving macro gravy Parametric Programing 2 02-22-2010 04:05 PM
Fanuc Serial Number Macro TomL21 G-Code Programing 4 05-08-2009 08:36 AM
Tool Serial Number Lookup jcollazo Calibration & Measurement 1 10-06-2008 02:23 PM
Missing Tool Number barbter NCPlot G-Code editor / backplotter 1 10-04-2008 10:07 AM
Dx-32 auto N number for you jtree83 Bridgeport and Hardinge Mills 4 09-26-2005 01:28 PM
