Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 06-15-2009, 03:27 PM
John Wales is on a distinguished road
Fanuc and Mach 3
Hi Gerry
I still have lots of questions about Mach.
I'm learning everything new including g code.
I wrote a small prog in Fanuc. (#101 , #102 etc.) It sort of ran in Mach 3 in simulated mode. I did not try to cut anything. The idea was to make a grid so I could match my code against it. The main prog makes four lines then the subprog is supposed to carry on with others.
The fanuc variables from #100 to #149 are global. The subprogram alters a global variable but the main program does not see the change. My question is, what standard does Mach 3 follow so that I won't get caught again?
The prog is here. More is needed but this part won't work the way it should.
G90 G21
#101=20
#102=10
#110=0
G0 X0 Y0
z-0.1
M98 P101
#110 = [#110 +1]
M98 P101
#110 = [#110 +1]
M98 P101
#110 = [#110 +1]
M98 P101
M30
O101
g0 y[#101]
g0 x[#102 * [#110 +1]] y[#101]
g0 x[#102 * [#110 +1]] y0.000
g0 x[#102 + [#102 * [#110 +1]]] y0.000
M99
Thanks for any and all help.
John Wales
Need Help!- integrating fanuc ac drive w/mach 3 texasfiddler Mach Mill 3 09-29-2009 11:07 PM
Have anyone experience mach fitting fanuc systems? Jonne Machines running Mach Software 0 04-17-2007 12:48 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
