Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 05-25-2009, 06:33 AM
Countryman is on a distinguished road
Spindle speed & Mach3
I am just building a CNC mill and need to get information on the spindle speed into Mach3. I did a search on this Forum but had no hits. Can anybody direct me to a Tutorial or guide as to what hardware etc. I need?
Cheers.
Old 05-25-2009, 06:39 AM
TOTALLYRC is on a distinguished road
RTFM or some such thing.
Originally Posted by Countryman View Post
Cheers.
Here is the link to the manual and it should be handy at all times. I have done three machine and I still refer to it o a regular basis as it is so involved it is impossible for me to remember everyting that is in it.
http://www.machsupport.com/docs/Mach...all_Config.pdf
Your question is kind of broad and I am not sure exactly what you are trying to do.
Mike
Old 05-25-2009, 08:53 AM
Hi Mike,
Many thanks indeed for your response. Between the manual you referenced and the one for my 'all in one' controller card I think I understand what to do.
I have a reflective optical switch which pulses once for each turn of the spindle. I need this to feed +5v pulses to the BoB section which interfaces Pin 10 (say) to the parallel port. In the Mach3 setup I need to assign Pin 10 / Port 1 to 'Spindle Index' and enable it. I should then have a speed reading on the Mach3 screen. My Mill has a DC motor with PWM module but I think that interfacing that will be more work than it is worth.
Thanks again!
Cheers.
Spindle Speed Control for X3 with C11G BOB & Mach3 MRM RCModels Benchtop Machines 24 07-26-2008 12:39 PM
MACH3 to control spindle speed of Wabeco F1210E pdyer Benchtop Machines 0 07-23-2008 12:34 AM
SX3 spindle speed control with Mach3 bbox Benchtop Machines 47 07-05-2008 05:15 PM
Spindle speed and tach for MACH3 chrispy Mach Software (ArtSoft software) 16 04-05-2008 08:25 AM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
