| Hi Guys, could you please help me with this problem. I have a Mach 3 Mill with a Mpg Pendant that I hooked up. When I use the Mpg pendant and move in minus the machine moves in plus, this happens in all axises. I am sure it is some setting in Mach 3, but am just not sure where to find it. The pendant is a usb standard they sell on ebay for $160. Arturo Duncan sells them. Thanks alot, Pat |
| If you jog with the keyboard, does it move in the correct direction, or the same as the mpg?
| Thanks Gerry for your input. Arturo got back with me, and his solution worked. In the Mach3 config pins and ports the #1mpg a pin and a port was 2 and 2. Pin b was 2 and b port was 3. Arturo said to reverse them. And it worked. Thanks, Pat |
| Problem- axis goes plus or minus on it's own | glentner | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-24-2008 07:53 PM |
| Starting at MINUS Z depth problem | SScnc | Vectric | 5 | 09-20-2008 08:58 PM |
| g-code reversed?? | mastertech | General CAM Discussion | 1 | 02-26-2008 02:20 PM |
| Y axis reversed | Legion99999 | Syil Products | 7 | 03-03-2007 11:43 PM |
