Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 03-24-2009, 07:17 PM
foamcutter is on a distinguished road
Trouble with Shapes wizard
I have been trying to get the shapes wizard to work but it keeps messing up. I wanted to cut a rectangle exterior cut so that the center was proud of the outside. Tried to run it twice going from bottom zero up on entering data and once from top zero going down using neg depth of cut. I starts out great then somewhere randomly it will make a normal cut then the next cut will be twice the depth, or it will make a cut at say -.02 like I want it to the next cut will be -0.03 and the next -0.04 then will finish the pass at that depth. Start the next pass going down from the last lowest cut, run like that for a while then do it again. I have turned everything off in the background on the computor before starting Mach3. The numbers the program shows for the depth are the correct numbers for what I want it to cut when it's running even when it messes up. Checked stepper and lead screw and couplers and they are tight. Never had this problem running any other wizard or program. My software is all licensed. Problem only shows up in the Shapes wizard. Any one have any idea what is going on? Thanks for any help Ron
Farm animal shapes PlasmaGuy CNC Plasma and Waterjet Machines 2 03-21-2008 01:47 PM
Nesting Wizard, Mach3 internal wizard. thuffner3 Mach Software (ArtSoft software) 1 03-04-2007 08:38 PM
Scan-Import Shapes edwardpic CNC Plasma and Waterjet Machines 2 10-04-2006 11:41 AM
Shapes Wizard rweatherly Mach Wizards, Macros, & Addons 0 05-23-2006 08:24 AM
Surfaces with Human Shapes CAMFUN General CAM Discussion 15 06-22-2005 08:18 AM
