Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 03-06-2009, 07:58 AM
chilly2k is on a distinguished road
Incremental Vs Absolute mode
I'm trying to setup the auto zero Probe and running into problems. From another thread I was able to conclude my problem dealt with incremental Vs absolute mode. (G91 vs G90). I tried coding a GetIJMode to find the current mode and reset to absolute if it was incremental.
The problem I'm finding is GetIJMode is returning the IJMode set in the configuration panel and not the actual IJMode that is active.
Also the IJMode indicator on the diagnostic page also shows the setting and not the actual mode.
I'm running Mach 3 Mill Version R3.042.020
Thanks Bob
Old 03-06-2009, 08:12 AM
ger21's Avatar
IJ mode is not G90 and G91. You're talking about two different settings.
Off the top of my head I don't know how to tell whether you're in G90 or G91 mode??
Old 03-06-2009, 09:03 AM
Thumbs up
Gerry,
Thanks for streering me in the right direction. Here is the code to set the mode.
MoveMode = GetOEMLED(49)
If MoveMode <> 0 Then
Code "G90"
Code "(Mode was incremental)"
End If
Then to reset
Code "G91"
Code "(resetting incremental mode)"
End If
The messages can be deleted. They were there for testing.
Thanks Again. I think this solves my problem.
By the way. A complete Newbie question. What is the difference between IJmode and co-ordinate mode?
Old 03-06-2009, 10:31 AM
ger21's Avatar
IJ mode is for arcs, it specifies the center point.
When I posted before, I was looking for that LED number, but I think I was looking for a DRO by mistake.
Old 03-06-2009, 04:54 PM
Greolt is on a distinguished road
Bob
If you're interested I have rewritten my Zero Macro to take care of the G90 G91 issue.
It can be found at this post, http://www.cnczone.com/forums/showpo...&postcount=257
Greg
Need Help!- Subroutine and Absolute/Incremental VWbmx G-Code Programing 15 02-22-2009 01:09 PM
What is - Torque Mode? Position Mode? Speed/Velocity Mode? sunmix Servo Motors and Drives 25 10-26-2008 03:53 AM
Offsets: Changing between absolute and incremental MotorCityMinion Haas Mills 11 03-04-2007 10:57 AM
Absolute or Incremental mikede Haas Mills 1 02-03-2007 05:02 PM
Absolute and Incremental ACME G-Code Programing 3 09-04-2004 05:45 PM
