Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 01-30-2009, 07:12 AM
kiltjim is on a distinguished road
Auto Tool Zero VBA Code gives Syntax Error
I have programmed in VBA before, but usually when I make a mistake, I am told exactly what is wrong, or at least where it is. So now that I am trying to add the "Aussie Auto Tool Zero" code with a copper plate, I am lost.
The thread I am talking about is here: Another Aussie Auto Tool Zero Setter
I have added the copper plate, and verified that it is working through the diagnostics screen.
I edited the standard screen to include an LED and a user DRO for the plate thickness input.
I then simply copied and pasted the code into the already present auto tool zero button.
Here is the code I used:
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P2" ' this delay gives me time to get from computer to hold probe in place
Code "G31Z-20 F100" 'probing move, can set the feed rate here as well as how far to move
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
Code "G0 Z20" 'put the Z retract height you want here
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Code "F" &CurrentFeed 'Returns to prior feed rate
Else
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
Exit Sub
End If
I know I will have to change the distances and the feedrates, but I haven't even gotten it to move at all. As soon as I click on the button, it comes up with a syntax error.
Am I missing something else that needs editted in the screen? Or am I missing something even more basic?
Let me know if you need any more information, I am not sure what else someone may need to diagnose the problem, or point me in the right direction.
Old 02-02-2009, 12:52 PM
Nevermind.
I am still not sure what was wrong, but I used some code from mach support site instead of the code listed, and it all works fine. If anyone wishes to clear up why the above code didn't work, by all means, though!
Old 02-02-2009, 06:32 PM
Greolt is on a distinguished road
kiltjim
The code you posted looks good. Don't know why it was not working for you.
Just to be sure I was not missing some small typo, I pasted it directly from your post into Mach's VB scripter window and it ran as it should.
What version of Mach are you running? There have been some versions with with problems running VB
Greg
Auto tool zero wildcat Mach Mill 30 10-08-2010 12:03 PM
Problems with auto tool zero Mephysto Mach Software (ArtSoft software) 3 12-14-2008 07:43 PM
Auto cad 3d draw to g-code jorgeneo560 Autodesk Software (Autocad, Inventor etc) 5 08-03-2008 01:27 AM
Auto Tool Zero Moondog Machines running Mach Software 13 12-22-2006 07:02 PM
syntax error pyroracing85 G-Code Programing 9 01-27-2005 08:09 PM
