| There's a plugin that uses a webcam and laser, but there's very little documentation for it. http://www.machsupport.com/forum/ind...oard,67.0.html
| You can use touch probes also, like one from IMS service or a Renishaw type contact probe. You have to keep in mind limitations of a probing setup. Don't have time to go into it but ball diameter can cause some problems, depends on how accurate you have to be. Also the length of the probe may limit you also since you mention it is a big part. I have a renishaw setup I run with MAch 3 so I have some experience. |
Hi Not really that hard to do. Please see my photos of my home made touch probe. You can either run a wizard from the mach 3 screen ( Wizards, pick wizard, digitization wizard) or download the probe plugin from the Mach Artsoft website. You will have to connect the touch probe to an unused input and configure it in Ports and Pins in the Mcah main scrren and then you are in business. Any questions please ask and I will try and steer you in the correct direction. My homemade probe is extremely successful and I get about 0.007 mm variance if I probe a flat object, however this goes up to about 0.05 if I run the vertical probing speed at 400mm/min (the former figure is at 50mm/min) Best regards Peter Williams |
| Unfortunately the later version add-on is non functional as far as I can tell. Mach 2, 3, are really great software but forget about using the digitizing part of it. L
__________________ Is a sentance fragment? |
| I just put a laser pen into the spindle held lightly by a collet and tool holder. Lay the object on the table and go around it drawing it on the laptop using the numbers given by the readout on the machine. I use Alphacam to draw and cut but you can also use anytype of drawing software. Use 3 points to define your archs' and Radii. This is very simple and only cost me $3.50 for the Laser pen. I have done a lot of decking for Yachts using this method working from their paterns both paper and wood when they could not supply the drawing.
__________________ We all live in Tents! Some live in content others live in discontent. |
| He wants to do 3D probing over a surface.
| Help needed with Mach 3 and Art Fenerty Digitizing Wizard | Evolution VIII | Digitizing and Laser Digitizing | 9 | 09-17-2010 06:27 AM |
| using a CNC / Mach software for digitizing? other ideas? | Rich05 | Digitizing and Laser Digitizing | 0 | 01-14-2009 11:12 AM |
| mach 2, xylotex and homemade digitizing probe | gun_mike | Benchtop Machines | 9 | 03-16-2008 09:50 PM |
| Digitizing software? | DennisCNC | Digitizing and Laser Digitizing | 6 | 01-14-2007 10:40 PM |
| Graphic digitizing software | DennisCNC | Digitizing and Laser Digitizing | 1 | 10-24-2005 07:54 PM |
