Hi, I try to write some macro, one for probing on the Z axis and one to measure tool offset, with no great success. When I run the macro for the tool offset, I don't understand why, instead of changing only the Dro(42) if also change the value of the Z Axis as well as the Z offset value Dro(49) Those macro a a little bit mixed up since I Have try so many things Macro to probe on the Z Axis SetOemDro (824,2) ProbeLength = 5.288 HauteurTable = -4.6205 HauteurMesureurOutil = -3.8295 Code"G0 G53 X-.4 Y-29.03 Z-5.5" If GetOemLed (825) <> 0 Then '(Please, Insert Connector in PROBE INPUT) Else FeedCurrent = GetOemDRO(818) Code "F5" ZNew = Zcurrent - 12 Code "G31 Z" &ZNew While IsMoving() Wend ToolPosition = GetOemDro(85) ToolOffset = tooPosition - 3.8295 NewToolOffset = 5.288 - ToolOffset SetOemDRO(42,NewToolOffset) Code "G53 G0 Z-1" Code"F" &FeedCurrent End If Macro for tool setter CurrentFeed = GetOemDRO(818) 'Get the current feedrate. HauteurTable = -4.6205 ProbeLenght = 4.6102 ProbeFeed = 4.0 'probing feedrate Tool_Num = GetDRO(24) ZHomeSwitch = 0 SetDro(24,1) Code "G90 F" &ProbeFeed If GetOemLed (825)=0 Then Code "G31Z-5 F" &ProbeFeed While IsMoving() Wend Code "G4 P0.25" ZProbePos = GetVar(2002) Code "G0 Z" &ZProbePos While IsMoving () Wend PositionApresPalpage = GetDro(802) PositionZG54= ZHomeSwitch-PositionApresPalpage Call SetDro (2,0) Call SetDro (18,PositionApresPalpage) Code "G4 P0.5" 'Pause for Dro to update. Code "G0 G53 Z -0.5" 'Change the Z retract height here Code "(Z axis is now zeroed)" Code "F" &CurrentFeed Else Code "(Plate is grounded, check connection and try again)" Exit Sub End If The length of the probe is 5.288(from under the spindle) When I probe the table top, this give a value of -4.620 If I add 5.288 + 4.620 this give 9.908 from under the spindle to the table top When I probe the tool setter, this give me a value of -3.8295 If I add 5.288 + 3.8295, this give 9.175 under the spindle to the tool setter For the G54, this would be 9.908 - 5.288 - DroZ The tool setter is fixed on the side of the table I have trouble to put the result in the Dro I have many problems using GetVar(2002) What is the difference between an OemDro and Dro Any help would be greatly appreciated. Thanks |
| TOOL SETTER WITH G50??? | DublJ | Fanuc | 0 | 07-30-2008 08:28 AM |
| Tool Setter | GARY DAVIS | Fadal | 6 | 03-18-2008 08:44 PM |
| What will cause this tool setter problem? | Hogger | Daewoo/Doosan | 3 | 01-03-2007 08:52 AM |
| Setting up a Tool Setter. | Smackre | Mach Software (ArtSoft software) | 6 | 06-16-2006 11:41 PM |
| tool setter | ACME | General Metalwork Discussion | 8 | 07-30-2005 12:15 PM |
