Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
  #505   Ban this user!
Old 01-16-2012, 09:39 PM
jstefano is on a distinguished road
Originally Posted by Jay C View Post
Have a look at https://picasaweb.google.com/1175904...17992883319634 Yes, I have one wire for Ground, and the other to the probe with a pull-up resistor. I added a cap from ground to Vcc and one from probe to Ground. This helped remove any noise since I didn't use shield cables and didn't want to risk breakage or ruined work. My spindle is not grounded to my mill so I couldn't rely on a common ground to the tool or plate. Mine is the C10.
-Jay
Jay,
How is it that your spindle is not grounded to your mill? Are you using Mach3?
  #506   Ban this user!
Old 01-21-2012, 04:10 PM
Jay C is on a distinguished road
Originally Posted by jstefano View Post
Jay,
I don't have a ground wire to my mill (which is aluminum). The spindle is a Bosch Colt, and the outer casing is thermoplastic. There may be a common ground with respect to the mains, but not good enough for a probe signal.
-Jay
  #507   Ban this user!
Old 01-21-2012, 11:51 PM
kaartman is on a distinguished road
Z Zero script editing
I would like to use the z zero touch plate with the indexer, how would i go about changing the script, to zero the cutter in the center of the workpiece.
I have copied the script here,and add a picture for a better understanding, I would like the cutter to retract 25mm above the flat surface ( yellow rectangle) that i use to find z zero, from the flat surface the Z is 75 mm downward, how would i go about editing the script below to accomplish this
'Rem Probe Down by PEU (Based on Erniebro Work)
FeedCurrent = GetOemDRO(818) 'Get the current settings
ZCurrent = GetOemDro(802)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "F100" 'slow feed rate to 100 MM/MIN
GageH = GetUserDRO(1152)
ZNew = ZCurrent - 20 'probe down 20 mm
Code "G31 Z" &ZNew
While IsMoving()
Wend
Call SetDro (2,GageH)
FinalMove = GageH * 2
Code "G0 Z" &FinalMove
Code "F" &FeedCurrent 'restore starting feed rate
The problem that i have is that the Z- axis retract the height of the 'gauge block' ( using the height from the centre to the top) resulting in the Z to run into the Z max hard stop
Thank you
K
  #508   Ban this user!
Old 01-24-2012, 04:30 AM
dwalsh62 is on a distinguished road
I'm no rocket scientist and know nothing about VBscripts and need a zeroing script so I begin my search.
What puzzles me is that there is one script for metric and another for imperial.
Is it that difficult to code the script to be intelligent and detect the mode and adjust accordingly?
Why is it so difficult to find a decent script?
Why is the sanity of the script at the bare minimum?
You have to weed through so much crap to find snippets of code that it almost seems hopeless to find a good solution.
Perhaps I'm better off just writing one based on the information I can find and add intelligence to it since there doesn't seem to be such a solution available.
Old 01-24-2012, 05:36 AM
ger21's Avatar
The thread below this one has code that works for both imperial and metric.
http://www.cnczone.com/forums/mach_w...r_big-tex.html
  #510   Ban this user!
Old 01-27-2012, 03:21 PM
While there are options available like the "Big Tex" solution, it's still two separate scripts and you would have to switch the script for the particular job.
I've come up with a solution based on several scripts and information I found (which they all seem to be based on) using the basic command substructure and added some sanity/entropy to ensure safety and reliability under any working condition.
What I personally disliked about the "Big-Tex" and other similar scripts is that they require the use of custom screen sets, what I created works with the standard screen set or any screen set you want to install it in provided it is based on the default input/data storage fields.
While I could have added the functions to employ axis relocation I think that the simple cancel so you can use the jog to X and Y coordinates is an acceptable alternative.
Turning off the spindle if it's on and starting it back up (in the direction it was turning) is a safety precaution that preserves the touch plate/probe if you get ahead of yourself.
Working from metric (G21/G71) or imperial (G20/G70) state is considered in the process so you don't have issues in either state and these states are restored when the script has finished so one script works under all scenarios.
This is what I came up with and bear in mind, I'm not a script writter and this is my first attempt at such things but due to background do have some clue how to write and comment code for later reference.
Code:
' Auto Tool Zero by Dale Walsh <dale@daleenterprise.com>
Dim Answer ' a discardable storage variable for general consumption
Dim Initial_Abs_Inc
Dim Initial_Feed_Rate
Dim Initial_G_State
Dim Initial_Machine_Coordinates_State
Dim Initial_Spindle_CW_State
Dim Initial_Spindle_CCW_State
Dim Initial_Spindle_State
Dim Initial_Tool_Offset_State
Dim Probing_Feed_Rate
Dim Guage_Block_Height
Dim Z_Probe_Pos
Initial_Feed_Rate = GetOEMDRO(818)
Initial_G_State = GetOEMDRO(819)
Initial_Machine_Coordinates_State = GetOEMLed(16)
Initial_Tool_Offset_State = GetOEMLED(28)
Initial_Abs_Inc = GetOEMDRO(48)
Guage_Block_Height = GetOEMDRO(1001)
If Guage_Block_Height <= 0 Then
	Answer = MsgBox("A positive value must be entered for the Guage Block Height", 0, "Oops!!!")
	Exit Sub
End If
If GetOEMDRO(824) <= 0 Then
	Answer = MsgBox("A Tool has not been selected, select a tool and try again.", 0, "Oops!!!")
	Exit Sub
End If
If IsSuchSignal(22) Then ' Check whether a probe input is defined..
	If GetOEMLed(825) = 0 Then ' Check to see if it's already tripped
		Answer = MsgBox("Do you need to Move X, Y or Z ?", 4, "Do you need to Move")
		If Answer = 6 Then
			Message("Tool Zeroing to Material was canceled so you can change coordinates.")
			Exit Sub
		End If
		Answer = MsgBox("Place Sensor on work piece.", 1, "Is the Guage Block Sensor in place")
		If Answer = 2 Then
			Message("Tool Zeroing to Material was canceled.")
			Exit Sub
		End If
		Message("Tool Zeroing to Material is requested.")
		' Save settings for restoring later
		Initial_Spindle_State = GetOEMLED(11)
		Initial_Spindle_CW_State = GetOEMLED(164)
		Initial_Spindle_CCW_State = GetOEMLED(165)
		If Initial_Spindle_State = true Then  ' Spindle is running so stop it
			 If Initial_Spindle_CW_State = Initial_Spindle_CCW_State Then
				MsgBox("Your running spindle is misconfigured -> clockwise = " &  Initial_Spindle_CW_State & " and counter-clockwise" &  Initial_Spindle_CCW_State & " , please fix this.")
				Exit Sub
			End If
			DoSpinStop()
			Sleep(500)
		End if
		' Turn off Tool Offset if it's on
		Select Case Initial_Tool_Offset_State
			Case True
				DoOEMButton(136)
		End Select
		' Turn off Machine Coordinates if on
		Select Case Initial_Machine_Coordinates_State
			Case True
				DoOEMButton(180)
		End Select
		'  Get current scale settings.
		XScale = GetOEMDRO(59)
		YScale = GetOEMDRO(60)
		ZScale = GetOEMDRO(61)
		'  Set scale to one to probe.
		Call SetOEMDRO(59, 1)
		Call SetOEMDRO(60, 1)
		Call SetOEMDRO(61, 1)
		Select Case GetOEMLED(802)
			Case true ' Metric System
				Probing_Feed_Rate = 150
				Probe_Travel = 250
			Case false ' Imperial System
				Probing_Feed_Rate = 6
				Probe_Travel = 10
		End Select
		DoOemButton(1010)
		Code "G4 P1"
		' Perform the probe
		Code "G90 G31 Z-" & Probe_Travel & " F" & Probing_Feed_Rate
		While IsMoving()
		Wend
		Z_Probe_Pos = GetVar(2002)
		Code "G0 Z" &Z_Probe_Pos
		While IsMoving()
		Wend
		Call SetOemDRO(802 , Guage_Block_Height)
		Code "G4 P0.500"
		DoButton(24) ' Home Z-axis
		While IsMoving()
		Wend
		Message("Tool is now zeroed to Material.")
		' Restore the original settings
		Code "F" &Initial_Feed_Rate
		' Restore the original G mode
		Select Case Initial_Abs_Inc
			Case 0
				Code "G90"
			Case 1
				Code "G91"
			Case 2
				Code "G92"
		End Select
		' Restore the original G state
		Select Case Initial_G_State
			Case 0
				Code "G0"
			Case 1
				Code "G1"
		End Select
		Select Case Initial_Spindle_State
			Case True ' Spindle is running so stop it
				If Initial_Spindle_CW_State = true Then
					DoSpinCW()
				ElseIf Initial_Spindle_CCW_State = true Then
					DoSpinCCW()
				End If
		End Select
		' Restore the original Tool Offset state
			Case True
				DoOEMButton(136)
		End Select
		' Restore original  Machine Coordinates State
			Case True
				DoOEMButton(179)
		End Select
		Call SetOEMDRO(59, XScale)
		Call SetOEMDRO(60, YScale)
		Call SetOEMDRO(61, ZScale)
	Else
		'  Houston we have a problem
		Answer = MsgBox("Guage Height Block is grounded, check connections and try again", 0, "Oh-oh")
	End If
Else
	Answer = MsgBox("Probe is not defined in" & Chr(13) & Chr(13) & """Config->Ports and Pins->Input Signals""" & Chr(13) & Chr(13) & Chr(9) & "configure and try again.", 0, "Oh-oh")
End If
  #511   Ban this user!
Old 04-18-2012, 12:38 AM
Bob La Londe is on a distinguished road
Thanks for the great tutorial. I had got basic probing figured out and working already, but your little tutorial, and the Blue Screen set with the auto center finding works great. I have some jigs I made with keys on the back for consistent mounting and recessed registers on the front for locating center for mounting certain types of things. I was able to find center easily enough with a wiggler on my slower spindles, but I was wasting tons of time with the faster spindles because I had to use the notebook paper and precision rod method. Can't spin a wiggler very fast or it comes apart. LOL.
Thansk for taking the time to put it together.
Bob La Londe ~ Owner of two and a quarter G540s.
www.YumaBassMan.com
  #512   Ban this user!
Old 05-22-2012, 06:19 AM
chlluk is on a distinguished road
Hi
A great article, i am having a few problems with the edge finding utility.
Firstly i find that using my chinese 5 axis breakout board on pin 15 i tend to get logic drift, that is i can get the input port to show a connection on the mach blu screen fine but when the testing has stopped the test light can stay on until i make contact again , this appears to rectify the condition. i have a capaictor in place on the board down to the ground. i wonder wether a resistor is needed to crow bar it down and stop it drifting. not sure what causes this condition , wonderdered if the opto isolators used on the board contribute to this. Also i think the magority of users this side of the pond are now metric and the 2" travel turns out to be 2mm for us, any way to cahnge this.
Clive
  #513   Ban this user!
Old 05-22-2012, 09:41 AM
Vogavt is on a distinguished road
Touch Probe as Homing and Limit Switches
Anyone thought about using this routine for an easy setup for homing and limit switches?
I would think that it would be much more accurate and repeatable than any mechanical switch setup. Especially if using the two-touch routine at each reference point.
Wouldn't it also eliminate any issues with water/coolant intrusion within the switches?
Just a thought, but maybe I'm missing something. (I've been known to do that).
Vogavt
  #514   Ban this user!
Old 05-23-2012, 09:52 PM
arudson is on a distinguished road
Screen Image
Hi. I was very happy to stumbe upon this post and I am eager to try this out.
I downloaded and ran the file as indicated and put the MacBlue_ProgramRun.jpg in the correct subdirectory. When I run Mach and load MachBlue my screen is not proportioned properly – it looks exactly like what James had in XYZ Probe modification.
I have chcked my resolution and it’s 1024 x 768 and I don’t have any previous versions of this file – I only have the BlueProbeVer3.zip version that is referenced in the posts.
Any help would be appreciated.
I played with this a bit longer - an now I get
I've tried this every which way and can't get it right.
Alan Rudson.
  #515   Ban this user!
Old 05-24-2012, 10:21 AM
Lightbulb
Have you toggled the Hi-Res Screens or Auto-Screen Enlarge checkboxes under Config | General Config?
Name:	Screen Control.JPG‎
  #516   Ban this user!
Old 05-24-2012, 08:05 PM
Got it
I tried the sequence about a dozen more times and finally it was right. I don't know what I was doing wrong but it's all good now.
Alan Rudson.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
PATRIOT Y AXIS MODIFICATION smallblock Shopmaster/Shoptask 4 10-02-2008 08:04 AM
Super Probe 17 Functions in one probe thegimpster PIC Programing / Design 0 01-25-2008 12:46 PM
4 X 10 table modification impax PlasmaCam 6 01-15-2008 08:04 PM
Y Axis modification Mike F Syil Products 6 11-12-2007 04:23 PM
New MCG's need modification Swede Servo Motors and Drives 3 01-12-2005 08:46 AM
