Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 02-19-2008, 01:32 PM
Need TECH Help!'s Avatar
Need TECH Help! is on a distinguished road
Lightbulb 2 Axis CNC
Hello,
I am new to Mach 3,and am retrofitting a Bridgeport type Knee Mill.
It has a exsisting control that is old and VERY weak.I am using the glass scales as encoders,and i already have the encoder board from rogers machine.Scales work great with Mach 3 as a DRO.Have not put Mach 3 control on machine and tested steppers yet,but have everything i need.Just waiting for machine to get "freed up" to do so.
I altered the original Mach 3 screen sets,and that is about all i know how to do as far as customizing Mach 3.
I am wanting to be able to use this machine as a 2 axis with Z axis DRO and also a full 3 Axis.Example ( Prototrack) If doing a bolt hole program in 2 axis (and blind holes) X and Y needs to stop at each point and wait with stepper motors "energized" or holding position,and waiting for me to hit Cycle Start to go to next point or hole.Z axis needs to be able to give DRO while running a program.
As of now to use as a DRO on all axis i need to be in Settings screen and RESET.
Brian at Mach 3 said that this can be done,and suggested i try here to see if i could find someone.As i know he is busy and dont want to bother him anymore than i already haveThanks again Brian
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 07:31 AM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 01:38 PM
Using X axis table moter for knee X axis imatoymaker General Metal Working Machines 1 09-10-2007 08:23 AM
A 5-axis CNC machine including a rotary axis synthetiklone CNC Wood Router Project Log 9 08-17-2007 10:11 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
