Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 01-08-2008, 11:56 AM
Jonne is on a distinguished road
Problem with Mach3 Brains...
I have problem Spindle Override % DRO. I want
set that DRO via ModBus.
My system works something like this:
CuTouch logic module read spindle override pot
and saves value to D-register. Mach3 read that
D-reg via Modbus and set value to Spindle Override % DRO.
I can see from Brain view thats working ok, but
Spindle Override % DRO stand still... What is problem?
And I have same problem with Jog feedrate, brain
output shows right value but it do not change anything...
I'm very, very tired of Mach3... Please help soon, my
head is exploding...
Regards, J Thelen Finland
Old 01-13-2008, 10:35 AM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Make sure you are updated to the latest version of Mach3
Old 01-14-2008, 06:22 AM
H.O H.O is offline
H.O is on a distinguished road
That should work. I have some info on my web-site that shows how I did exactly that (and more) with a CUBLOC CB405 module. It worked fine at the time.
Also, I don't think it matters but do you have Mach3 out of E-Stop mode?
Old 01-14-2008, 07:48 AM
Hello
I have read and I obey your instructions, but no help...
By to way, thanks great site, it helps me lot!
I use latest version of Mach3: V3.00. I think Mach3
is problem, similar topics is in Mach3 support forum...
I'll try use macros to avoid problem until
new release comes out...
Is there any function like MODIO? I mean function what I
can use macro programs. And is there Mach3 customizing
documents? Only what I have found is some old
"Customizing Mach2"-manual and print year is something 1910
Thanks afterwards!
problem with Mach3 jed102 Mach Software (ArtSoft software) 5 01-27-2008 05:38 PM
Problem G00 by Mach3 with G100 olo_3olo_3 G-REX 0 11-30-2007 08:12 PM
Problem with Mach3 SCOTTY76SA SheetCam 3 05-27-2007 09:34 AM
Mach 2 loosing brains after loading gcode (Scale gets way off) Any Ideas InventorJohn Mach Mill 6 01-12-2007 11:42 AM
The brains of the operation teilhardo Mechanical Calculations/Engineering Design 5 07-04-2005 01:17 PM
