Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 11-23-2007, 11:15 AM
Normsthename is on a distinguished road
Auto Tool Zero VB problem
I have had my homebuilt metal CNC router working just fine for about a year now
Last week I upgraded the Mach3 software to the latest version and I forgot to do a backup of the directories before I installed it, and it overwrote my VB code for the Auto Tool Zero button
Because my machine will not work correctly with the 'automatic' code I manually lower the Z axis while watching the diagnostic screen, as soon as the probe registers that the bit has touched the plate, I then press the Auto Tool Zero button.
This then puts the thickness of my plate (7.96mm) into the Z DRO and raises the Z Axis to 15mm above the workpiece ready for cutting.
This is the code I have tried :-
code "G92 Z7.96" 'This is the thickness of the plate that I touch off
code "G0Z15"
This works fine but once the part has finished cutting, the Z axis DRO changes its value to the actual Z axis machine height.
Anyone know how I can get the Z axis to keep the previous tool offset?
TIA
Andy
Another Aussie Auto Tool Zero Setter Greolt CNC Wood Router Project Log 452 01-18-2012 08:02 PM
Auto tool zero wildcat Mach Mill 30 10-08-2010 12:03 PM
The Zbot from LMS(auto tool changer) RedDog22 Benchtop Machines 10 04-01-2010 10:15 PM
Tool Change - Can I set it to auto stop? inthezone Fanuc 16 01-22-2008 06:56 PM
Auto Tool Zero Moondog Machines running Mach Software 13 12-22-2006 07:02 PM
