Results 1 to 3 of 3
Thread: gamepad help
    Feb 2007
    gamepad help
    I have connected a gamepad to my USB and enabled the Mach3 joystick plug-in to control the x and y axis. How can I program this to take advantage of the other buttons/keys?
    Mar 2003
    Shelby Twp, MI....USA
    I think you may need to use keygrabber.
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    This is extreme (& cool), should help you.
    Like Ger21 said, use keygrabber.
    http://www.hossmachine.com/projects_2.html#control panel
    I took 2 USB controllers, an aluminum case, a bunch of switches and some wire and came
    up with this.
    I use Keygrabber from Mach 3 to program the buttons.
    I can control (4) 110 V accessories, i.e. the engraver, surface grinder, light, vacuum.
    I have a duplicate X2 Speed Control switch from Littlemachineshop.com.
    I added Jogging feedhold switches with LED's for taking long 'manual' cuts.
    Still have about 10 buttons unused available for future plans.(maybe Mach 4?)
    Bought the Logitech USB Attach 3 and the Phillips USB PC Controller at Walmart.
    I bought the aluminum enclosure and switches at Mouser.com.
    This Panel gives me control over the most used buttons in Mach3 for quickly jogging
    the tool into position for a cut then starting the Gcode. The joystick works like in a game,
    the farther I push to one Axis or another, the faster it moves. I'll include my tutorial for
    programming KeyGrabber below.
