Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 08-12-2007, 11:19 AM
josesabaris is on a distinguished road
Help Override Wich Macros
Good Morning, I Have Constructed A Plasma That Works Perfedtamente, But Need To Reduce The Speed In Circles And Corners, By The Problem Of The Cut Angle, I Proved To Reduce It By Means Of Instruction "f" Of Gcode But When It Is A Solid Line Continuous Line Of Trenches, I Circulate And Solid Line Continuous Line Of Trenches, The Plasma Is Stopped To Start At Another Speed, As It Did Not Work Very Well I Decided To Change The "fro" Of The Feddrate, This Way Varying The Percentage It Machine Not To Change Of Speed, But The Macro Does Not Work To Me, And Not So That It Does Not Work, If Somebody Can Alludar To Me Would Thank For It, Os I Leave To The Macro And A Square Generated In Code G So That To Probe
File Type: zip GCODE AND MACRO.zip‎ (880 Bytes, 70 views)
Wich spindle is best?? quant General Metal Working Machines 4 06-23-2007 11:24 AM
does somebody know, wich software? BL4ST General CAM Discussion 2 02-15-2007 09:09 AM
Wich leadscrew? (how much TPI) CnC_BoY DIY-CNC Router Table Machines 34 03-25-2006 03:20 PM
spindle override imca38x Fadal 1 09-09-2005 12:25 PM
Feedrate Override JFettig TurboCNC 2 12-09-2004 07:17 PM
