Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 06-05-2007, 03:23 PM
bigz1's Avatar
bigz1 is on a distinguished road
Numeric Pad Pendant Setup??
I have just bought a Numeric Keypad to use as a pendant. Could you please explain how I set it up?
Also would be intrested to know what functions you would recommend be assigned to which keys and why?
I have cut a few things on my DIY machine but am still very much a newbie to this.
Old 09-03-2008, 10:57 AM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Gcode and Machine Movement
If I write the code below:
X1
Y1
X0
Y0
And save it it only displays:
X1
Y1
X0
And when it runs it moves:
X+1
Y+1
X-1
X-1
There are 4 moves but it doesn't make a square.
Confused??
Where am i going wrong?
Old 09-03-2008, 11:05 AM
ger21's Avatar
Make sure you hit enter after typing the last line, then save after hitting enter.
Old 09-03-2008, 11:23 AM
Mr.Chips's Avatar
Gold Member
That was the answer.
In Motor Tuning, "Steps Per"
If the steps were set to 32,000 and then to 16,000 should the square still be 1" square. In my case it is.
What does it change when you change the "Steps Per"?
Old 10-29-2008, 01:18 AM
xjdubber is on a distinguished road
hijack?
general numeric 6 control alarm list rexe Machine Problems, Solutions , Wireless DNC, serial port 1 11-03-2010 09:56 AM
GN6 (General Numeric) Helical milling pauldkeeton Fanuc 5 02-23-2007 04:42 PM
Possible jog pendant? mrosso Screen Layouts, Post Processors & Misc 0 02-14-2007 04:09 PM
MPG pendant troy676zsj Fadal 0 07-30-2006 10:15 PM
Pendant? CNCadmin Carken Products (Deskam, DeskCNC etc) 0 05-07-2004 10:10 AM
