Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 04-28-2007, 10:23 AM
ProDrawerCom
IQChallenged is on a distinguished road
Aconcentric circle pocket
Just now getting up and running. Doing test cuts in styrofoam. Used circular pocket in Mach Wizard. Result is very noticeable out of round pocket. Is this a known problem or is it my machine? I'll try another code in the mean time.
Old 04-29-2007, 06:11 AM
Kipper's Avatar
Kipper is on a distinguished road
Are the units setup correctly? Or is there backlash on one axis?
Keith
Old 04-29-2007, 08:32 AM
ger21's Avatar
It's probably you're machine. Try doing some plain circles with G2/G3.
Old 04-29-2007, 09:28 AM
ProDrawerCom
Lost
Don't know how to do that. Can you give me the complete gcode. I do know how to type or paste into notepad and then get it into mach3.
Let's say a 3" dia and .25" deep pocket. Thank you.
Old 04-29-2007, 09:30 AM
ger21's Avatar
What size tool?
Old 04-29-2007, 09:44 AM
ger21's Avatar
Here's a circle and one with pocket, assuming a 1/4" tool.
File Type: txt 3incircle.txt‎ (205 Bytes, 94 views)
Old 04-29-2007, 10:28 AM
ProDrawerCom
Thanks so much for being there for us. The code produced a circle 10.25" in diameter. Then I adjusted Mach for 1/2 scale. The smaller one more clearly shows the defect (flat spots). What do you think?
Old 04-29-2007, 10:50 AM
ger21's Avatar
In the general config, make sure your IJ mode is set to incremental. that should make the circle 3". Looks like backlash on 1 axis.
Old 04-29-2007, 11:08 AM
ProDrawerCom
That's the one word I didn't want to hear. Worked so hard to make sure I wouldn't have any. I bet you know a code that would reveal whether it's the X or the Y.
Old 04-29-2007, 11:25 AM
ger21's Avatar
It's in whatever axis is up and down in your pic.
  #11   Ban this user!
Old 04-29-2007, 11:36 AM
ProDrawerCom
Backlash
Okay. That would be my Y. I'll check for play. I know there's an electronic adjustment also. Does that really work?
  #12   Ban this user!
Old 04-29-2007, 12:09 PM
ProDrawerCom
Already there
[QUOTE=ger21;make sure your IJ mode is set to incremental. that should make the circle 3". [/QUOTE]
It was already there. What else would make the circle larger than the code specified?
The Perfect Circle - Need Help ScoobyDoo FeatureCAM CAD/CAM 11 01-17-2007 05:41 PM
Circle problem Captain Midnigh Milltronics 3 11-09-2006 03:11 PM
Circle instead of radius Prboz Mach Mill 7 10-01-2006 10:13 PM
milling a circle osomaker Fadal 7 08-13-2006 09:04 PM
Milling a Circle rcazwillis General Metalwork Discussion 15 04-19-2005 09:21 AM
