Page 3 of 3 FirstFirst 123
Results 25 to 29 of 29
Thread: Aconcentric circle pocket
  1. #25
    ProDrawerCom
    Apr 2006
    Calibrating or Putting Mach & Machine on same sheet of music
    Quote Originally Posted by bigz1 View Post
    Am just a newbie myself. But could it be your axis setup is wrong? You can check for this in 'Settings Alt6'. Just above the reset button is a button for axis calibration marked 'Set Steps to Unit'. The other mistake I made was changing the mm to inches in 'Select Native units' in the config drop down menu.
    You may be alluding to a feature I've wondered about before. And I think someone even said it was there but I can't figure out how to do it. Let's say that my machine moves 11.937 inches when I gcode it to go 12.000 inches. Is there any way to simply type in the difference (0.063") and have the machine ZERO itself? Thank you
    http://projectcnc.wordpress.com/
  2. #26
    Registered bigz1's Avatar
    Apr 2006
    NZ
    You dont have to type any G-code just press the button select which axis you want to calibrate. It will then ask for distance you want to travel. The relevant axis should then move and MACH will ask how far it actually travelled and then update the axis calibration for you. Far simpler to do than to explain. Just have a play with it.
  3. #27
    ProDrawerCom
    Apr 2006
    Calibrating an axis
    I think I figured out how to do it. I think it goes like this SETTINGS>SET STEPS PER UNIT>X AXIS>OK>HOW FAR....>(SEE 0 HIGHLIGHTED)>OK
    However, on my MACH, nothing happens when I type in a number. It's as if my numlock was turned off. It may be because I'm still using the MACH trial version. Don't know.
  4. #28
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by IQChallenged View Post
    I think it's a bug, I saw the same thing. It starts with a highlighted 0, and like you said, typing a number doesn't do anything. Click once in the box to remove the highlight, then drag over the 0 to re -highlight it. Then I can type in my number.
  • #29
    Registered Kipper's Avatar
    Jul 2006
    England
    Quote Originally Posted by ger21 View Post
    I haven't noticed that bug (found a few speeling errors in the wizards though )and I've used the feature several times :shrug: (I'm using Version R2.0.008) <Found under help/about mach3 cnc controller
    Keith
  • Page 3 of 3 FirstFirst 123
    1. The Perfect Circle - Need Help
      By ScoobyDoo in forum FeatureCAM CAD/CAM
      Last Post: 01-17-2007, 05:41 PM
    2. Circle problem
      By Captain Midnigh in forum Milltronics
      Last Post: 11-09-2006, 03:11 PM
    3. Circle instead of radius
      By Prboz in forum Mach Mill
      Last Post: 10-01-2006, 10:13 PM
    4. milling a circle
      By osomaker in forum Fadal
      Last Post: 08-13-2006, 09:04 PM
    5. Milling a Circle
      By rcazwillis in forum General Metalwork Discussion
      Last Post: 04-19-2005, 09:21 AM
