Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 11-02-2006, 02:49 PM
kb7vms is on a distinguished road
circle cutting wizard problem
Trying to cut a circle about x0 y0 of diameter 1.75". Wizard outputs code ok, but the circle is the wrong size, and is not centered on x0y0. What am i missing? Is there something else that needs to be set?
Very new to this stuff, but always learning.
Ray
Old 11-02-2006, 05:28 PM
ger21's Avatar
Aee you using the circle cutting wizard by Kiran? Are you hitting "enter" after entering the info. You specify the center, and radius right in the wizard. It works fine here.
Old 11-02-2006, 07:55 PM
Yep told it x and y are zero, and diameter is 1.625. But when i post and run the code it makes a spiral. Almost hit my vise before i killed it.
Thought there may be something in settings that would affect the i and j terms.
I even tried G2 manually thru the MDI screen. But still dont have a good grasp on the terms. got circles, but wrong diameter and offset from center.
But thanks for the input;
Ray
Old 11-02-2006, 08:57 PM
ger21's Avatar
Try changing your I,J mode to incremental. I didn't think of that.
Old 11-03-2006, 01:47 AM
Where is that control performed?
Ray
Old 11-03-2006, 02:08 AM
timlkallam is on a distinguished road
http://www.kentechinc.com/tip7.html
It has a circle milling program you can download
Tim
Old 11-03-2006, 06:08 AM
ger21's Avatar
Ray
Config>State
Old 11-06-2006, 12:14 AM
well got the circle cut 2" dia in 0.5" plate steel. just used MDI mode and set I and j to zero and it worked.
Thanks for the help.
Ray
