Hello to ALL
... I have a Mill type Bf20 home made CNC ...and all was working well until two days ago..the X homing suddelly stopped to work ! I cheked:
- limit switch=all ok
- sensor= all ok
- cable= all ok
- cable continuity by analogic tester= all ok
The breakboard works fine, I used a new sensor for testing it, but the signal in position 10 is not received by Mach3. Maybe is a print port defect?
Thanks for any help!!
hi Troncatore, did you solve the problem with your input signal?
I also I have the same problem, I get no signal input from limits and MP300-ubobIIdthc. not turn on LEDs on the diagnostic screen
