| HELLO ! So this is my problem : I generate a Gcode in mach3 wizard thats ok works fine int mach3. But i move this code to a big CNC /fadal 4020/ it doesnt work properly cose the whole numbers are not lookint like this 20.0 or 20. ![]() In mach 20 is 20 but in fadal 20 is 0.020. so this makes a bit problem to "convert" a bigger code to suite fadal... ![]() so after every number i have to put a dot or a dot and 0. Is there a way to change the post processor script to make decimal point or trailing zeros to whole numbers ???
__________________ FADAL VMC4020 HT 1995, Z 28" (if true) , 88HS , 10K rmp , 21 TC geneva /rotary/ , 3ph 400V , metric, NO conveyor, No palette. |
| You'll need to modify the the wizard's VB code to get it to do what you want.
| OK... ![]() How can i do that ? i have to do some editing in some file ? Do you have a MSN or Skype address ? Akos
| Generally, with the wizard open, go to Operator > Edit Button Script and click on the flashing button that usually says "Post G-Code" or "Create G-Code" This will open the VB editor with the VB code for the wizard. You'll need to modify this code to output the g-code the way you want it. That all the help I can offer.
| Problem- Decimal point in a comment? | Brakeman Bob | Fanuc | 4 | 04-22-2010 01:47 AM |
| Need Help!- V21 decimal point adjustment needed | AirChunk | BobCad-Cam | 2 | 01-17-2010 07:34 PM |
| decimal point Gcodes G90.1 G91.1 | Karl_T | CamSoft Products | 0 | 10-22-2009 02:24 PM |
| Forcing a decimal point from a pci | inflateable | EdgeCam | 0 | 10-28-2008 08:58 AM |
| decimal point | stevieboy | Mastercam | 9 | 01-10-2007 05:42 AM |
