Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 01-06-2012, 05:17 PM
CATCH22 is on a distinguished road
Question How should my limit switches be wired?
The limit switches on my cnc mill are wired so that when the limit is pressed in it makes a connection,I would think that it would be safer the opposite way so that the connection is broken when the limit is pressed,that way if a wire broke or came undone that would trigger the limit.The limits are N.O. and N.C.
Can anyone help me out with this one?
Thanks Mike
Old 01-06-2012, 05:30 PM
Al_The_Man's Avatar
This is the Mach forum so I assume you are running this as a control, if so the switches can be configured either way?
Old 01-06-2012, 07:40 PM
Yes I will be running Mach3,and thanks Al.
Old 03-09-2012, 07:57 PM
Odie9 is on a distinguished road
I have mine wired as normally closed (NO) for just that reason. Then if the connection is broken anywhere you'll know immediately.
Odie9
Need Help!- Home switches and Limit Switches TheBulk DIY-CNC Router Table Machines 5 03-12-2011 05:08 AM
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
