Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 12-05-2011, 06:39 PM
AiR_GuNNeR is on a distinguished road
Thumbs up Updated plugin available for the ShuttleRU pendant
I've released an important update for the ShuttleRU pendant, both the LCD and non LCD versions.
Download
The several changes are detailed on Andrey's website, but the one I want to tell you about is a Momentary Shift-Red option. Now you can safely keep setup functions, like homing and zeroing out the DRO's in "Red" mode, and you won't accidentally use one of these functions because you forgot you are in the "Red" mode rather than "Green" mode.
If you assign one of the 15 buttons to this new function, then the normal mode button will be ignored, and you will need to hold down the assigned shift button while pressing the button whose Red function you want to execute.
I've come up with an optimal layout for the buttons, and would be happy to share it, (in the form of a Corel Draw file).
Regards,
Eric Sanders
SoarSoft Software
Tags
pendant, shuttleru
New plugins available for ShuttleRU pendant AiR_GuNNeR Mach Wizards, Macros, & Addons 0 11-02-2011 12:43 PM
Photoshop plugin? bpoulin Laser Engraving & Cutting Machines 5 11-16-2010 02:28 PM
where to get SC updated? eeenhy SprutCAM 2 07-01-2010 11:54 AM
TurboCAD CAM plugin Fluxion TurboCAD/CAM 10 06-27-2009 02:37 PM
