Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 11-08-2011, 10:29 AM
travisn is on a distinguished road
g53 in macro/script?
Running a syil x4 with mach3
I set up the auto tool function to work with a touch off plate. But I want the auto-tool button to send the tool up and then over to the plate location.
It is located at -9.798,-.577, -7.502 in machine coordinates. I tired using g53 but got an error that machine coordinates are not allowed in the script. So now I have to remember to find the m6 call out each time and enter g53 x-9.798 y-.577 before the m6 line. It's not really a pain to do since we run short programs, I just don't want to ruin anything as I am not the only one who uses the machine.
How can I go about doing this?
Thanks,
Old 11-08-2011, 10:41 AM
ger21's Avatar
You can use
Code "G0 G53 X-9.798 Y-0.577 Z-7.502"
in your script.
Old 11-08-2011, 10:47 AM
Wow, thanks.
So I just needed g0 before the g53 command?
Old 11-08-2011, 10:53 AM
also, since I have your attention, what do I use to make mach3 wait before going to the next line? I want it to finish moving before displaying a msgbox advising to change tool now or that the job is finished.
Old 11-08-2011, 10:54 AM
ger21's Avatar
I don't know, as I've never seen the error you got, or what you were trying to do. But what I posted will do what you want.
Old 11-09-2011, 12:36 PM
fidia is on a distinguished road
A dwell could be used, G4PX where X = num of seconds
Old 11-09-2011, 04:55 PM
ger21's Avatar
Anytime you have movement occurring in a script, it should be followed by:
While IsMoving
Wend
To make sure the move is completed before further code is run.
If you want to pause, use:
Sleep(1000)
for 1 second. (# is milliseconds)
It's good practice that anytime DRO's need to be updated, that a minimum of 1/10 second delay ( Sleep(100) )be used to allow the DRO's to update before moving on. Failure to do so may cause problems.
Old 11-10-2011, 09:45 PM
got it, thanks. I'll update my script tomorrow.
next task is making a pnp....
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
Newbie- VB6,VB.net,VB script,What one??? hydrospin01 Visual Basic 11 05-24-2008 08:09 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
Lookahead Script Rikard L General CNC (Mill and Lathe) Control Software (NC) 0 09-10-2007 02:06 PM
Macro/script-can this be done? Splint Rhino 3D 3 02-12-2006 09:50 PM
