Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 08-02-2011, 01:41 AM
niteowl is on a distinguished road
Question Mach 3 Digitize Wizzard G31 issue
I am trying to run the gcode from the digitize wizzard and everything looks good except the G31 probe down to Z 0.0 stops after traveling a very short distance from the extract distance of .4". The part I am working on is lower than the travel distance of the G31 so the part is never touched currently. I tried looking at the Mach3 config's related to Z travel and nothing jumps out as a problem. The machine operates fine in normal milling operations that do not use a G31.
It's late, I must be missing something.
Any assistance will be appreciated.
Cheers,
Don
Old 08-02-2011, 06:10 AM
ger21's Avatar
It might be noise triggering your probe.
Where do you have Z zero set? If it's above your part, the probe will never touch the part.
Old 08-02-2011, 11:29 AM
Thanks, Z 0.0 is set to the surface below the part. I will check the noise idea, but the light does not come on and it is very consistent.
Don
Old 08-02-2011, 01:12 PM
I recall that I did have early vibration problems jogging Z at 10 IPM but increased it to 30 IPM and the problem while jogging went away. I can try jogging x or y at 10 IPM and see what happens. It may be that the step-over could cause a similar effect. My homemade probe allows for variable spring tension so I can try stiffening it up a bit.
Don
Old 08-02-2011, 01:22 PM
ger21's Avatar
If it's noise, Mach3 will detect it before the LED comes on, so you won't see it.
Old 08-03-2011, 12:00 AM
Gerry,
Yes, noise it is. I started the probe code going and applied downward pressure on the probe by grabbing it and it went all the way down to Z 0.0. I increased the tension on the springs and the noise issue went away but now the probe sometimes doesn't re-seat when deflected from the side. The probe guides are not preventing probe rotation under the increased spring tension. I need to re-engineer the guides it appears.
Thanks for your help.
Cheers,
Don
Tags
mach3 g31
Newbie- Cambam issue or Mach 3 Issue?? tracyranson CamBam 11 07-11-2011 10:03 AM
Need Help!- Mach3, Probe, and Digitize Wizard Issue vicrider Mach Wizards, Macros, & Addons 2 06-02-2011 01:58 AM
Old Dahlgren Wizzard XL Popeye Engraving Machines 0 04-19-2011 10:42 AM
Need Help!- code wizzard Siemens BDsaint EdgeCam 6 11-10-2010 11:45 AM
Need Mach 2/3 Wizzard Quick! elalto Employment Opportunity 4 07-19-2005 11:44 AM
