Nbanwart
Try posting a screen shot of the wizard after you have entered all the parameters.
John
I'm currently a brand new CNC owner trying to use the Mach3 engraving wizard. However for some reason it's keeping the x, y, values constant so it just moves the z axis up and down. Help please![]()
Nbanwart
John
You need to pick the direction you want it to go towards.
There are 4 options 0 degrees, 90 degrees, 180 degrees or 270 degrees. Going from left to right you will want to pick 0 degrees. Hope this helps.
Gage
