| Hello. I run a fadal 2016L at my work. And the fadal got a button called "Slide Hold". Can i fix my emergency stop in mach3 (im using gecko 540) like a "Slide Hold" button so i dont missing any step when i use it? Greetings from Robert.
__________________ My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html |
| No. Use the Feedhold instead.
| yeah, but the feedhold is not turning "on" before the g code line is finish? so if i run x100mm with a feed 60mm/min. it goes to x100, THEN stop. Understand? ![]() Greetings from Robert.
| Try checking "No FRO on Que" in General Config.
Hello again... I try that, but it doesn`t change.... Some other tip? Greetings from Robert.
| Mazak T-2 "20 NMI Emergency Stop" Error" | Jeff_Y | Mazak, Mitsubishi, Mazatrol | 13 | 01-11-2011 10:35 AM |
| M2 External Outputs - Feed Hold, Emergency Stop | nlh | Mazak, Mitsubishi, Mazatrol | 1 | 06-22-2009 08:49 AM |
| Where do I install an emergency stop button? | alexccmeister | Stepper Motors and Drives | 36 | 04-21-2007 06:40 PM |
| Arcade Button Emergency Stop | mikkojay | Gecko Drives | 5 | 06-07-2006 12:30 AM |
| Mach2 bombs when I hit the "stop" button | Stuff-Builder | Mach Software (ArtSoft software) | 4 | 09-28-2005 10:09 AM |
