Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 02-23-2011, 03:15 AM
Vegabond's Avatar
Vegabond is on a distinguished road
Gecko 540, mach3 and limit switches.
Hello.
I need some help to get my limit switches working...
I put the wires in the gecko (port 1-4) but i can`t get it work in the mach3.
What do i need to do with the ports and pin, active low..... and all that?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Old 02-23-2011, 07:36 AM
Action-KAT's Avatar
Action-KAT is on a distinguished road
Hi Vega
My understanding Normal set-up for limit switch
one wire goes to one of the Gecko's ports 1/2/3 or 4
the other wire from the switch goes to your power supply -VDC.
then in Mach3 you tell which axis the switch is for ie x/y or Z home or limit.
bepending how you have wired the switch set for active high or low
If you are unsure Mach3 can set it for you by selecting auto and trip the switch manually for Mach3 to see it, then Mach3 sets to Hi or Low as needed.
hope this helps
Old 02-23-2011, 07:47 AM
Action-KAT's Avatar
I have just check it is page 63 of the Mach3Mill_Install_Config.pdf
on the Input Signals Tab
If you select the Home or Limit - / + for the required switch
bottom right of that screen click the Automated Setup of Inputs
then follow the instructions and manually trip the switch when requested.
easy setup really unless you have wired the switch wrong
Old 03-05-2011, 04:42 PM
Vegabond's Avatar
Hello again.
Thanx for that!
But how can i change the homing speed?
Old 03-05-2011, 05:05 PM
Action-KAT's Avatar
Hi Vegabond
To alter the homing speed goto the Config menu
Under Homing/Limits
alter the speed %
hope this helps
Old 03-05-2011, 05:11 PM
Vegabond's Avatar
Yeah it help
Thanks!
Robert.
VSDEPI, Mach3 and limit switches stevespo Granite Devices 25 02-18-2011 03:59 PM
Got a Gecko G540, now which limit switches and E-Stop? CNC Lurker DIY-CNC Router Table Machines 19 12-06-2010 03:13 AM
Mach3 and limit switches ZigMan Mach Software (ArtSoft software) 2 07-21-2008 04:52 PM
Need Help!- G100, Mach3 and Limit Switches wiring shah G-REX 2 05-06-2008 01:15 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
