Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 02-20-2011, 02:28 AM
shridhar is on a distinguished road
Mach3 for ID grinding machine
I want to build a CNC ID grinding machine with Mach3 control. I need some experts help for the following:
1. Either a macro or subroutine to do wheel dressing for every pass or final pass.
2. How to set the compensation for the tool wear after dressing?
3. Can chinese 2.2KW water cooled spindle be used here?
Regards,
Shridhar
Need Help!- Buderous Grinding Machine M.RISHIKESH CNC Wire Foam Cutter Machines 1 10-18-2011 10:50 PM
Ejector pin grinding/cut off machine? Chuck Reamer Moldmaking 19 10-15-2011 05:58 AM
ROLL GRINDING MACHINE keyancnc CNCzone Club House 1 06-23-2010 10:05 AM
Milling Machine and Surface Grinding dpaish General Metal Working Machines 3 02-05-2010 10:59 AM
Problem- Oerlikon B24 grinding machine with vibration in Z axis cervanp CNC Machining Centers 0 08-28-2008 02:02 AM
