Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 01-13-2011, 03:58 PM
KnotsAboutWood is on a distinguished road
Exclamation A simple Z homing setup
Hi guys,
I'm wondering if anyone could help me get a simple Z homing device setup?
Here's what I've done.
I got this information from Build Your Own CNC Router Machine and it's not working for me. I've posted over there (below is most of my post from that site) and no one has answered, so I decided to see if anyone at this site can help.
First here's my configuration.
In Mach 3:
Under Input Signals: Z Home enabled pin 13
Under Homing Limits Z (checked) Home Negative & Auto Zero (checked)
On my breakout board I have a wire going from the pin 13 connector and another wire hooked to the 5V slot next to it (in the appropriate direction)
It's my belief after watching the video that I should now be able to hit the REF ALL button and the machine will move till it completes a circuit in any direction that's enabled in the homing Limits section.
So my problem is when I hit the REF ALL button, I get nothing. (I've checked to make sure that the M3 light lights up when I touch the wires together.)The machine doesn't move. I checked to make sure that everything was still working by jogging the machine and adding manual g-code.
Any idea on why it wouldn't be working, or any ideas on where to go from here. Zeroing by eye just doesn't work very well .
I'm just looking to zero the Z right now.
Any help would be appreciated.
Old 01-13-2011, 04:26 PM
ger21's Avatar
1) Do you actually have a switch attached to the machine? It doesn't sound like it, when you mentioned touching the wires together?
2) Home Negative should NOT be checked for the Z axis. The home switch should be at the top of the Z axis, in the + direction.
3) Is there any error message when you click the Ref All button?
Old 01-13-2011, 06:58 PM
Gerry,
1) No switch yet. I was planning to attach the wire to the plate after I made sure it worked by touching the wires together.
2) OK, I'll uncheck Home Negative.
3) There's no error message when I click REF ALL or when I click REF Z in Diagnostics.
Old 01-13-2011, 07:00 PM
ger21's Avatar
On the diagnostic page, the the yellow Z Home LED light up when you touch the wires together?
Old 01-13-2011, 09:04 PM
Yes. That was one of the first tests I did.
Homing question/setup Regnar LinuxCNC (formerly EMC2) 1 05-22-2010 04:06 AM
homing/limit setup Thorpydo Benchtop Machines 3 01-04-2010 12:46 AM
Need Help!- Homing and Limits Setup Mr.Chips Mach Software (ArtSoft software) 33 01-21-2009 09:12 PM
How to setup homing in Syil X3 albatros62 Syil Products 5 11-11-2007 12:14 AM
what is the best homing and limit switch setup? Bryscnc Machines running Mach Software 1 09-28-2006 05:37 AM
