Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 11-17-2010, 05:47 PM
Ark1 is on a distinguished road
Loading XML File.
Could some one direct me on how to install the XML file for a Sound Logic 1.9 board. I have the file, I have dropped and expanded it in my Mach3 folder, but it currently doesn't change the configuration for my pins and port address for the board in Mach3. I have the licence and I have been trying to install this file and get it to work for over an hour. The Bob Campbell user manual states click on the Mach 2 or 3 icon, not Mach2 or 3 mill, I have Mach turn and Mach plazma but I do not see a Mach3 icon. It then speaks of a drop down box with a list of profies and to select Sound Logic. I don't see this box or know where to find it to do the selection.
Currently I am lost. If there is a link or screen shot of this it would be most welcomed.
Thanks for your help.
Ark1.
Old 11-17-2010, 06:41 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Find your mach3.exe file, Right click on it and select send to desktop or create short cut. This will place the icon on your desktop, You can also just double click the mach3.exe file and it will bring up the mach3 loader, then you should be able to select the profile.
Old 11-17-2010, 06:53 PM
Gary I have that icon and the drop down box but the sound logic selection isn't in that menu. My TosFN 20 Mill profile that I created is there but I know I am missing something.
I made the profile way before I got to this point of pins and ports. The Sound Logic manual is a bit lacking. I am sure once I learn how to configure a computer for CNC the 1st time it will be easy. Right now I still am stumped.
Thanks for the reply, any other thoughts?
Ark1
TonyK.
Old 11-17-2010, 07:53 PM
GaryCorlew's Avatar
it is possible that when you expanded the file it may have created a folder under the mach3 folder, if it did then you need to copy the xml file into you mach3 folder. When you go to your mach3 folder do you see the xml file there? does it have the .xml extension?
Old 11-18-2010, 06:20 AM
Gary thanks again for your replies. I will look tonight after work to see where this file has expanded to. From memory the Mach3 folder has several sub folders and I belive I saw a folder that you are speaking of. I really wish the Sound Logic would be more specific as the XML file is really a plug in compressed file once expanded I have no idea where it went to or what the file name should be. I will guess at this point that it may be Soundlogic.xml.
I suppose I could also take that compressed file and expand it into another folder then read what is in the expanded folder and then go looking for the file.
Possibly the file went into a sub folder, but I don't think that should make a difference?
Thanks for your replies and assistance.
Ark1
TonyK.
Old 11-18-2010, 06:27 AM
GaryCorlew's Avatar
It has to be in the main mach3 folder or you will not see it in the mach3 loader
Old 11-18-2010, 06:17 PM
Update.
Found the file and expanded and it made a sub folder. Still would not come down in the drop down box. I then added XML to the file name and now could select in the drop down box. On the lower right hand side on the main Mach3 screen it says SoundLogic. Great, but no ports have changed assignment and I cannot change the Kernel speed. At this time I have tried to use the diagnositc screen and look for a change in status light when I install a jumper on the X limit switch contacts. No change. Parrelle port cable checks out to be straight through, however my computer is not seeing the new 2 port card. Have tried to load driver and each time comes back unsuccessful with the CD. Since this computer stands alone I am going to run a LAN cable to my internet and have it search for an updated driver. Possible this will correct the problems I am having.
Any opinions are always welcomed.
Ark1.
TonyK.
Old 11-18-2010, 06:44 PM
GaryCorlew's Avatar
hopefully the internet will help you out but, do you know who the manufacturer of the card is? After you get the driver installed make sure you run the driver test(drivertest.exe) if that says everything is ok then fire up mach3 set your parallel port address then you should be ok. If you cannot make any changes to the setup(configuration) then go to the mach3 directory and right click on the xml file then look down near the bottom of the pop-up box select proprieties and make sure read only does not have a check mark in it, if it does click on it to clear it go back out and re-fire up mach3 and see if you can make changes then.
Old 11-18-2010, 08:18 PM
Not winning.
Managed to get the parallel ports to work with the computer. Now realized that with the card I now have 3 assigned. LPT 1, 2 and 3. Checked the address and on my ports and pins found address on Mach3 to be 0x378 found address on computer to be 0378 tried to change and save but each time I restarted the program it defaulted back to 0x378.
in frustration I uninstalled Mach3 and reinstalled, I now have the sound logic choice in the drop down box.
Question should this XML file set the ports and pins? Because it currently does nothing but show up in the bottom right hand corner of the main screen as Sound Logic. Also I now cannot start my computer with the BOB card connected as XP freezes and will not load past the Window XP logo page. If I unplug the D25B cable to the BOB and reboot I am fine then plug in once the computer is on the PC is fine. I have even tried enabling LPT2 and there is no difference. In the diagnostic page jumpering a home or limit does not communicate with the PC.
So 2 evenings latter I am no where other than getting 2 LPT ports configured and knowing my way around a menu or two.
Sinking fast here, just don't know what I am over looking. By trade I am an electrician, but have not worked with CNC drives or programs.
Any help is very much needed.
Thanks.
Ark1
TonyK.
Old 11-18-2010, 08:42 PM
GaryCorlew's Avatar
Ports no, pins yes, some, they do not know anything about your setup, so the basic ones will be set. I have never used one of these boards but they are all basically a-like. Do you actually have three ports? or two? I have one computer that does the same thng as your does when booting, so no problem with it hanging in my opinion just leave it unplugged till it boots. Is the port set to EPP mode? is it possible to set it to EPP mode? did you try some of the other port mappings? Once you make what ever changes you want to make there is an option at the bottom of the same drop down for saving your settings, Also the pin setting for your limit may not be the way you wired it, when you look at your pins for your limits make sure they are enabled, Do you know how to attach files to you message? if so attach you mxl and I will take a look at it and see if I can see any problems with it.
  #11   Ban this user!
Old 11-18-2010, 09:11 PM
What is EPP Mode?
Not sure what that term means.
Currently I installed another LPT board because I also have a Rodgers DRO board so that in the final stage I could use the Mill in manual mode and have a DRO. Currently the DRO board is mounted but I am going to push that back a bit until I have some progress here. Like getting the Sound Logic board to work as it should with Mach3.
At the present time the machine controller back board is in the basement where it is warmer and I can to the set up and testing. ( Live in Canada near Niagara Falls) Limit switch testing is only jumping the 2 connections on the board to see if the status light changes on the diagnostic screen. Once obtained then testing to prove the terminal wiring would be next. Not even close to that.
I might remove the 2 port card for now and see if that helps. Possibly there is a conflict with the board and my PC. It will be a few days before I can get back to this as my son ran into a parked car and I have the once side of my Dodge truck to repair. If I get the chance to try anything else I will post my progress.
Oh, the XML file you wanted to look at, the sound logic one? Lots of lines of code, personally I don't think it is loading in Mach3. I have sent an email to Bob Cullens of Sound Logic. Possilby there is a bug I need to know about as this board is the most recent release.
Here are a few pictures of my conversion.
Thanks so much for your time.
Ark1
TonyK.
ID:	119474   Click image for larger version
ID:	119475   Click image for larger version
  #12   Ban this user!
Old 11-18-2010, 09:41 PM
mactec54 is on a distinguished road
Ark1
Do you have the Estop wired,or a jumper will do for temp, if not nothing will work, untill the Estop is connected
Mactec54
Need Help!- Loading a file into Fanuc 21M idtkid Fanuc 12 09-25-2009 02:57 AM
Need Help!- Bridgeport Series 1 Boss 5 PC file loading Electricky Bridgeport and Hardinge Mills 1 08-06-2009 09:51 AM
CNC88HS file loading question MBX5 Fadal 8 06-13-2009 08:20 PM
Need Help!- File loading issue life3970 Milltronics 4 08-21-2008 11:00 AM
Need Help!- Error loading program file from USB on VF2 Mill... intoolerance Haas Mills 1 07-12-2008 05:30 PM
