Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 10-26-2010, 06:32 PM
CLEVELAND23 is on a distinguished road
***Renishaw Probe***
I have an renishaw probe on a horizontal mill..the feed is at 1.2ipm after first hit..anyone know how to change this value???? Takes a long time probing parts this way
Old 10-27-2010, 12:43 PM
HelicopterJohn's Avatar
HelicopterJohn is on a distinguished road
Probe Speed
Give Renishaw Technical Support a call. They can walk you through the process on how to modify the probing speed on a particular marco to suit your needs.
They were extremely helpful to me.
John
2007 HAAS TM-1P OneCNC XR4 Mill Pro. Shopbot PRT running Mach3, 2010 Screen Set, Super PID and PMDX Electronics. Check out my Gallery on: http://www.helicopterjohn.com/
Old 10-29-2010, 11:32 PM
renrepjnr is on a distinguished road
Feed rate adjustment in Renishaw software
CLEVELAND23
More than likely what you need to adjust to speed up the probing cycle times is the back of factor and not the feedrate of the second touch. Look to see what the back off factor is (#506) for Fanuc controls. Needs to be >0 and <1. Default is .5 Experiment on the bore cycle and Z single surface and keep dialing the BOF down by .1 until you get a probe open alarm and add .05 and verify that the cycles run consistently without probe open alarms.
Once you get everything dialed in recalibrate with the new settings.
Alternatively, depending on the control you have you can load a 1 touch macro which could run faster. But, usually you are better off going blazing fast (120ipm) on a first touch, backing off (as small of distance as possible), and then take a final touch at a slower feedrate (1.2ipm).
Old 11-02-2010, 05:58 PM
Thank You....Worked like a charm
This site is better then any tech service...
Fanuc oi md - renishaw probe Debo General CNC (Mill and Lathe) Control Software (NC) 1 07-20-2010 03:48 PM
Renishaw OMP 40 Probe twitte CNC Machining Centers 3 06-23-2010 11:52 PM
Newbie- Renishaw probe inertialabs Haas Mills 16 05-25-2009 05:54 PM
RENISHAW MP12 PROBE KLUCAS4 Cincinnati CNC 1 02-12-2009 12:49 AM
Mp7 Renishaw probe Cncjunkie CNC Machining Centers 5 02-02-2006 09:13 AM
