| Looks like lost steps. Does it only happen with the write wizard? Can you post the code?
Hi Here`s the code I ran. Thanks for taking a look. I believe the write wizard showed the problem. The other wizards seemed to act normal. I have been changing some of the config settings so its possible I created a problem. Thanks again for the help. Last edited by bgolash; 06-26-2005 at 05:20 PM. Reason: More detail |
| I loaded it into Mach3 and it looks fine. Have you had any problems with other programs on your machine.
| Is it binding anywhere? It looks like it only lost steps in one spot, if that is what the problem was.
| Hi Its possible its binding on the Y axis. For one, I have preloaded rails and also the 5/8 nook was bent in various spots. I am suprised it would loose steps because the steppers are 1200 oz|in and I was only running at 25 ipm. Is it binding anywhere? It looks like it only lost steps in one spot, if that is what the problem was. |
Hi It looks like I got the text to work correctly. I lowered my max speed of the steppers and lowered the cut speed to 10. I`m somewhat surprised that its necessary to run at such slow speeds to cut the letters. I`ve used most of the other mach2 wizards and didn`t have any lost step errors even when running a circle at 100 percent. Could I have missed something in the config files of Mach2 that could cause these step errors. Thanks |
| What drives are you using, and at what voltage? What are the current and voltag ratings on your steppers?
#10
The power supply is 51 VDC and Gecko G210 Motor Specs 1200 oz*in Holding Torque: oz*in 8.7 Rated Voltage 2.7 Rated Current 6.0 Resistance Ohms .45 Induction mH 5.1 |
#11
| bgolash I had the same problem with a simular machine to yours. I found that when I used the text wizard it worked my x and y axes hard causing the power suppley to be maxed. I found this out when I noticed the led lights on the Geckos dimming during the cuts. I ended up having to upgrade my power suppley to fix the problem. |
