Page 27 of 28 FirstFirst ... 172425262728 LastLast
Results 313 to 324 of 326
Thread: Mach 3 tool setter Big-tex version
  1. #313
    Jun 2009
    I just switched over from emc2 to Mach3 and set it up with Bug Ted's modmig works great! The auto z function was actually the reason I made the switch. One question though. Is there a way to set it up so that I don't have to put a wire with an alligator clip on the bit? I assume could run a ground wire from my g540 box to the router but is there another way? I have a relay hooked up to turn on the router but that downs't tie the grounds together. Can I jut run a ground from my power supply to the ground that the router plugs into? The outlet the router plugs into is already plugged into the same outlet as the power supply. I thought that would make it work but it doesn't.
    TIA
    Odie9
  2. #314
    Registered WoodSpinner's Avatar
    May 2010
    Hi Big-Tex, Thanks for the screen, I got it up and running right off. I was wondering what screen editor you used for this and does it matter if I use a different one?
    John
  3. #315
    Dec 2010
    Netherland
    Mach 3 tool setter Big-tex version Problem
    Hello
    I install the Big-tex bleu screen probe 3.3 in mach3 latest version
    I handeled as list in the read me first text file.
    But when i use intial zero setup the z axis only zeroed.
    The mill does not traveled to the X and Y coordinates given in the dro x and the dro y, I think it should do that .
    When i manuel go to the given in coordinates and than use initial zero set up it zeroed the z axis and goes to the begin point and zeroed z again and goes back to the point of coordinates I manual traveled and stopt.
    What do I wrong
    I hoop someone can help me.
    Thanks Harley
  4. #316
    May 2010
    I'm wondering if anyone has gone thru and fixed the erroneous button assignments and other non functioning parts of this screenset yet? I am considering trying it myself but dont want to reinvent the wheel if someone has already done the work.
    John
  • #317
    Jun 2008
    Uk
    I have a very early version of this macro. Can anyone give me a link to the latest version? A version that does not use the blue screenset would be better for me, just never could get to like it.
    Many thanks,
    Jeff.
  • #318
    Registered AJ Negvesky's Avatar
    Jun 2006
    Maybe I missed it somewhere. I was using the original MACH3 Blue screen set with the probe and the the X,Y and Z worked after a computer melt down I have installed the TEX version 3.2 and I am having weird results. the X and Y seem to work great but when I do the Z setting it lowers and touches the plate and raises to the safe height at that point it starts lowering again and embeds the bit into the touch plate? I am a little confused over this. When the bit lowers the second time it lowers at a much slower rate so I do have time to abort it. i am using the same buttons I used in the original probe screen set the buttons on the right with the x and y and a circle as well as the Z with the down arrow.
    Please help if possible..
  • #319
    May 2006
    I have purchased a shuttleru, and while I wait for it to arrive I am doing a bit of research on setting it up. I use the big tex screenset, and I am wondering how to get it so I can push a button on the pendant to get it to run the zero routines. Any help would be greatly appreciated.
  • #320
    Feb 2012
    I just picked up a logitech game controller and want to do the same thing. It looks like there is an option for a "touch tool" that a button can be assigned to but I'm at a math camp for my son this week so it will be a while before I can try it out to see if it works. Maybe someone with real experience on this can help us out?
  • #321
    Registered helliman 27's Avatar
    Oct 2011
    im new to this site. i need help with a height issue i used big texs macro and when i auto zero the tool comes down and touches the plate. plate zeros the tool.then i hit activate and the tool comes down to 0.65 above the my part and does not cut anything please help me its driving me crazy.
  • #322
    Aug 2012
    Ireland
    i`ve been messing around with cncs for years and only recently started using mach 3. Its a great program and when i came across Big Tex tool setter version things looked even better. his install went great and everything seems to be working but..... for some reason just the limit/home and probe leds on the diagnostic screen dont light when they are tripped, but the system works totally.
    any explanation to fix this bug would be great.
  • #323
    Mar 2009
    Georgia
    Hello
    Somebody know if this touch probe will work with smooth stepper?
    I used this before when I run the cnc directly from parallel port and worked perfect. Now I'm using USB Smooth Stepper.
    Thank you.
    Alex
  • #324
    Jun 2007
    italia
    A simply guide for tool probe in my blog.......PatRelief
    Thanks.
    [URL="http://patrelief.blogspot.it/"]http://patrelief.blogspot.it/[/URL]
  • Page 27 of 28 FirstFirst ... 172425262728 LastLast
    LinkBacks (?)
    1. Need Help!- Tool Setter Macro for M-V60C and Metrol Setter
      By mitshack in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-02-2013, 06:08 AM
    2. Tool Pre Setter
      By Allen123 in forum Mach Software (ArtSoft software)
      Last Post: 03-16-2009, 12:29 AM
    3. Need Help!- Tool setter macro for M-V60C and Metrol setter
      By mitshack in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-06-2008, 09:38 AM
    4. TOOL SETTER WITH G50???
      By DublJ in forum Fanuc
      Last Post: 07-30-2008, 08:28 AM
    5. Tool Setter
      By GARY DAVIS in forum Fadal
      Last Post: 03-18-2008, 08:44 PM
